1/4 times stock '05
Old Sep 24, 2005 | 09:36 PM
denile's Avatar
My 1/4 times stock '05
Here's 2 of my runs 1st time with the evo.Much different launching it compared to my gsx.
Track is @ 980'
Both runs were 12 minutes apart.
run #1
60'- 2.164
330- 5.952
1/8- 9.017@79.95
1000- 11.68
1/4- 13.927@100.53
run #2
60'- 2.090
330- 5.862
1/8- 8.949@77.76
1000- 11.630
1/4- 13.875@102.28
I know the 60's are terrible but can anyone see anything else that needs work.
trapping 102 I should be getting low 13's,right?
I did have a third run but I tried slipping the clutch a little more and it slipped through all of 1st and 2nd,so I quit for the night.
Old Sep 24, 2005 | 09:38 PM
Curt@MrLed's Avatar
Former Vendor
my 03 did 13.4 @ 104 stock.. i know my 05 will beat that.. yours should too..
Old Sep 24, 2005 | 09:40 PM
denile's Avatar
What track you run at?
Old Sep 24, 2005 | 09:44 PM
Curt@MrLed's Avatar
Former Vendor
numidia raceway by bloomsburg pa..
Old Sep 24, 2005 | 09:45 PM
denile's Avatar
Yeah,that's where this was.
Old Sep 26, 2005 | 04:57 PM
boosten's Avatar
hmmmmmmmmm
You guys must have some wensday evos or maybe the weather makes a diff. Because out in phoenix I have never seen a 03-05 evo hit low 13's . I seen a bone stock sti hit a 13.6 at 100mph and could not get better than that. You dont want to now what the other evos and sti's run stock.
Old Sep 26, 2005 | 04:59 PM
prospectevoER's Avatar
i was trapping 100 mph in my sti but my et was 13.2. car was bone stock with 18 inch wheels however which slowed my trap speed. you should def. be able to do low 13's as soon as you get your 60' in check.
Old Nov 7, 2005 | 04:49 PM
denile's Avatar
I found a reason my e.t.'s were high.Installed BR TBE and when I was under the car notice the tires were bald on the inner part of the tires,on the front only.Now I'm in need of an alignment,this would probably be the cause of the higher than stock time.
Old Nov 11, 2005 | 09:37 PM
MitsuEvoIIX's Avatar
just posted in another thread i ran tonight stock 05 ran a 1343@102 with a 2.06 and 13.26@101 with a 1.92
Old Nov 13, 2005 | 02:51 PM
05SilverEvoVIII's Avatar
check for boost leaks those are some bad times for an 05, low 13's man try again.
Old Nov 13, 2005 | 02:53 PM
Alignment on an 05 what the he** did you do to it to screw it up this quick.
