'05 Clutch In Rev Limiter
Autocross is my weekend sport of choice. We have to launch hard just like you drag racers because we too are playing a game of 10th's or 100th's of a second.
I hate the '05's clutch in 5K rev limiter. How do I get rid of it??
I have developed a sort of a technique but it's no where as quick a launch that I see from an '04 Evo competitor.
I posted this same question in the Motor Sports forum and got 2 opinions. One was disconnect the sensor wire from the clutch pedal but the other said don't do it because it causes the engine to run lean. So I didn't.
Help............what can be done to get rid of this silly rev limiter?
Thanks
Jim H.
ps. I did a search and didn't find anything.
Thanks
Jim H.
I know this sounds vague, but it is the top connector on the clutch pedal. It's a black plastic connector. Just disconnect it and your in bidness.
Be prepared to shed some blood in the tight quarters. It is well worth it. My 60' s went from 1.8x to 1.6x. Hope that helps.
Thanks
Jim H.
Thanks
Jim H.
Originally Posted by SiCKlEyWiKeD
same here, i've been using this thing for too long. I disconnected a wire from the clutch pedal but that didn't do anything but make my car start without the clutch.
There are 2 that you can disconnect... one for the limiter and one that makes the clutch be in to start the car... o yea search harder it's on here do an advanced search on "5000"
so just follow the pedal all the way up till i find it?
Yup, it is very helpful if you have a headlight (not on your car) a light that fits on your head.
Or maybe you ar egood with a flashlight while contorted under the dash panel. (I am not!)
Folloe it ALL THE WAY UP. And disconnect.
Guys, thanks for the help. And the search using "5000" helped too with the pictures.
No one seems to be concerned with the thought that disconnecting the clutch switch will cause the car to run lean so I'll go for it. What the heck, I've got 97,000 miles and 117 months of warranty left.
Jim H.
Jim H.
An easy way of seeing what your doing is removing the fuse panel. It pops right out and you can see what your unplugging up there. Takes me less than 20 seconds to disconnect the limiter.
franzcars
Jul 22, 2025 12:26 AM
BeyondLimitsEvo
Cobb AccessPORT
Jul 20, 2012 08:07 AM
lacartus
16
Dec 28, 2005 01:38 AM
