Best ACD setting for the strip?
Old Oct 24, 2005 | 08:20 PM
rACerS's Avatar
We just got an 05 and I was wondering what it should be set at for the strip. I have always just left it on tarmac. But It seems to really spin the front tires when launching. I thought the 05 would launch much better than our 03 because of the front LSD. But it seems like the 03 actually spun less out of the whole than the 05 does? Has anyone else experienced this?
thanks
Old Oct 24, 2005 | 08:31 PM
Warrtalon's Avatar
thanks
The FLSD just helps when dealing with tirespin while cornering. When launching, both front tires have equal power distribution. As far as the ACD is concerned, spinning in first would only get worse if you changed it from Tarmac.
Old Oct 24, 2005 | 08:37 PM
DCSilvrEvo's Avatar
I thought it would be better to have it on the gravel setting because it puts more power to the rear wheels isnt that better for launching?
Old Oct 24, 2005 | 08:41 PM
Warrtalon's Avatar
Tarmac puts the most to the rear. Technically, it's always 50/50, but the ACD settings change the point at which the diff locks. Tarmac is immediate while the other 2 are increasingly delayed, which makes it act more like a FWD...first with Gravel and then moreso with Snow.
Old Oct 24, 2005 | 09:14 PM
TrinaBabe's Avatar
I love the research people do
Old Oct 24, 2005 | 09:21 PM
rACerS's Avatar
And Im sure everyone loves your smart a$$ comments.
He was trying to help
Old Oct 25, 2005 | 08:07 AM
TrinaBabe's Avatar
I have been in a grumpy mood lately, sorry
It just sucks for alot of the people that do want to learn more about thier cars but get fed a ton of false information. That is why there are so many strange rumors and stupid ideas that people follow. Too many people that don't know try to answer questions. People should just let the people that truly know, aswer the questions. There would be much less theories floating around. Luckily for you other people did answer with knowledgable answers but imagine if they didnt.. or they did but without a good explanation. You would be at the track telling the car to put more power to the tires that are spinning and never run worth a crap.
Old Oct 25, 2005 | 02:52 PM
11secEVO7's Avatar
there's never more than 50% of power going to the rear..as far as i know.
tarmac 50/50
gravel i believe is 60/40
and snow is 70/30.
i always run on the tarmac setting
Old Oct 25, 2005 | 06:03 PM
mybada's Avatar
tarmac 50/50
and snow is 70/30.
I thought they are
tarmac 100/0 to 50/50 variable
gravel 50/50 locked
and snow is 70/30 locked
Correct me if I'm wrong but this is what I read from some magazine (don't ask me which one cuz I don't remember)
Old Oct 25, 2005 | 07:09 PM
Warrtalon's Avatar
Originally Posted by mybada
I thought they are
gravel 50/50 locked
It's always 50/50...always. The ACD settings just change the point at which the diff locks. I've never seen those ratios you mentioned.
Old Oct 25, 2005 | 07:38 PM
rACerS's Avatar
Understandable.
Thanks for the info. I appreciate it
It would be nice to have a t-case that sent more power to the rears.
Old Oct 25, 2005 | 11:18 PM
TrinaBabe's Avatar
Well you could in theory. It would make it 100% rear though. If you lock it with a welded viscous and made some sort of a way to block the oil from leaving the tranny and such you could toss out the front axles therefore sending all the power to the back obviously. Not really what you meant but it is the only way.
Old Oct 27, 2005 | 05:30 PM
evorent's Avatar
thanks
change std. ACD ecu to Gems ACD ,make mapping /3 different/ + off and play
Old Oct 27, 2005 | 05:35 PM
favre95's Avatar
Evo = Front biased
STI=Rear biased
Old Oct 27, 2005 | 06:42 PM
TrinaBabe's Avatar
Originally Posted by favre95
Evo = Front biased
STI=Rear biased
I dont recall someone asking that but thanks for the info
Ford F150 = Rear Biased
Chevy Caprice Classic = Rear Biased
Honda Civic = Front Biased
DSM = Front Biased
Ford Tempo = Front Biased
Hope that helps
