JUST BROKE 10's
Old Mar 25, 2006 | 01:49 PM
  #31
2003evo8's Avatar
Just ordered the clutch and i'll have it in a couple of days exeddy triple carbon, its will handle 900 hp they say we will see if it handels the track
Old Mar 28, 2006 | 06:11 PM
  #32
TrinaBabe's Avatar
It just shows how bad my driving is
You gain .5 seconds off my time by the 1/8th.
Nice shifting!
Old Mar 29, 2006 | 04:04 PM
  #33
2003evo8's Avatar
i also have more power than you also.
Old Mar 29, 2006 | 04:20 PM
  #34
AutoMotoSports's Avatar
Way To go. Send me an email with your mofications and and a nice picture and Ill try to get you on our website under featured cars.
Eric@amsperformance.com
Eric
Old Mar 29, 2006 | 06:54 PM
  #35
smp3000's Avatar
Yeah- would love to see some pics of the car
Old Mar 29, 2006 | 09:22 PM
  #36
C6C6CH3vo's Avatar
If trinababe is the same person as T.R. (initials) with an 04 in WI, then from what I understand the power should be close. Ithink
But then again if your car does weigh 3750 lbs + person then you have a tank and/or your a tank.
What clutch did you just waste, stock?
Old Mar 29, 2006 | 09:27 PM
  #37
4G63 T's Avatar
Hello...we need assesment and diagnosis....
where is Dr. warrtalon?
Old Mar 30, 2006 | 02:34 PM
  #38
2003evo8's Avatar
a twin plated exeddy clutch was the wasted clutch, a stock clutch would never hold that much power for all the tunning and runs that my car has been threw
  #39
2003evo8's Avatar
Just sent pictures to eric at AMS and hopefully they are up soon
Old Apr 1, 2006 | 05:40 PM
  #40
TrinaBabe's Avatar
I have trapped higher than you with horrid runs (11.8's) shifting slowly If I gave it a hard run and could actually drive/shift it well I would be much closer to 130 at the same boost.
Like here is a run that is funny I did today:
60' 1.892
1/8 7.878
mph 96.65
1/4 11.798
mph 126.76
That is at 26-27 psi.
Or one that my IC pipe blew off:
60' 1.887
1/8 7.574
mph 99.67
1/4 11.635
mph 108.21
As you can see my car needs some work
Old Apr 4, 2006 | 01:10 PM
  #41
C6C6CH3vo's Avatar
Originally Posted by TrinaBabe
60' 1.892
1/8 7.878
mph 96.65
1/4 11.798
mph 126.76
60' 1.887
1/8 7.574
mph 99.67
Judging from those times vs mph, You shift like a girl (not saying anything wrong with that) but have a 10 second car.
Don't worry I trap 88mph with 8.0ET so not only do I shift slower, my car is as well.
Old Apr 4, 2006 | 10:23 PM
  #42
TrinaBabe's Avatar
The car locked me out of shifting. Im trying to diagnose/fix the problem currently... HOPEFULLY I will get it fixed my Sunday and run it again. If I can fix the shifting problem I will finally see what the car can do. These shifts were VERY slow, every shift resulted in re-spooling the turbo from -11 in/mg and took about .5 seconds per shift. When I could shift fast the boost would only fall to about 22psi and take .3 seconds each. An example is when I shifted like this at really low boost I made a 12.01 @ 117... fixed the shifting and ran an 11.55 @ 123 without changing anything on the car one week later.
Im still not that good at the 1/8th so my honest guess for this weekend if I can fix it would be, at the same boost, a 10.8 @ 129-130.... and thats if I dont turn the boost up.
Old Apr 5, 2006 | 10:14 AM
  #43
mrcox's Avatar
I dont have a scanner but the slip says
r/t .153
60' 1.647
330 4.642
1/8 7.097
mph 97.05
1000 9.240
1/4 10.94
mph 126.79
The 1000' time does not seem right. It took you .3 of a second to go the length of a football field. That time should be around 8.9 or so.
Old Apr 7, 2006 | 02:46 PM
  #44
2003evo8's Avatar
Talking
i think i know whats wrong and why its locking up while shifting, i had the same problem, when i diagnos it it was either a bad pressure plate or air with in the tranny, so i tried the cheap way first and blead the tranny and that worked....
Old Apr 7, 2006 | 03:02 PM
  #45
evolved4g63's Avatar
Speeking of bad shifting, are you guys using short throws or the stock shifter?
