APC Drag Evo runs an 8
Old Mar 25, 2006 | 05:55 PM
EricJ@AMS's Avatar
Originally Posted by Asta4125
Uh, there have been faster. Adam from devo tuning has a video on his site of his evo goin 8.77. Ok now it isnt 8.76 but he has pulled faster times. Not sure on wether or not there have been an awd evo in the 7's. Rwd for sure, but not sure as far as awd.
It is generally agreed upon that that was a timing error, something that happens at Great Lakes Dragaway quite often. The 60' showed to be a .908 which is just not physicly possible for a unibody car. His fastest verified backed up pass was a 9.13, still fast as hell none the less.
I'd bet money that we will be seeing ALOT of 8 and 9 sec passes out of Evo's this year. Good job to the guys with the APC Evo!
Old Mar 25, 2006 | 06:02 PM
evo542's Avatar
only top fuel cars get like 1.05s 0-60ft
Old Mar 25, 2006 | 06:04 PM
blowoffsilver's Avatar
42 or 45?
Old Mar 25, 2006 | 08:52 PM
yelo3's Avatar
It runs a gt45 garrett, motec, and made on a dyno dynamics dyno 820hp at all 4 wheels on 33 psi boost.
Old Mar 26, 2006 | 02:53 AM
yelo3's Avatar
There are 2 vids up on my site www.drag-evolution.net Nicks 8.7 run and mr breaking my rear diff woo hoo
Old Mar 26, 2006 | 03:21 AM
Ang Wen Yan's Avatar
Congrats!!1
Old Mar 26, 2006 | 04:19 AM
Thugline's Avatar
The "Silver AMS evo" runs a 9.41 and has 808whp. But this guy is saying that his buddy has 820whp and runs an 8.7. Here is another pruven point about "Dynojets" having "Hyped *** #'s" and can never read accurately.
Old Mar 26, 2006 | 04:20 AM
Thugline's Avatar
Unbelievable!
Old Mar 26, 2006 | 04:56 AM
rawandbruteEVO's Avatar
motec m800 or 880?
Old Mar 26, 2006 | 05:32 AM
yelo3's Avatar
m880
Old Mar 26, 2006 | 06:06 AM
EricJ@AMS's Avatar
E.T. has little to do with wheel hp numbers. You need to do calculations based on mph and weight (not to mention many other factors like aerodynamics, how good of a pass it was, if it was ran at the same boost level as dyno'd, etc...), then make your assumptions about how inaccurate a Dynojet is. I see alot more inconsistancy with load bearing dyno's than I do with inertia dyno's anyway, but this has all been covered thousands of times before and I'll not get into it again.
Old Mar 26, 2006 | 07:37 AM
dome2dome's Avatar
Cool..
Old Mar 26, 2006 | 08:55 AM
PhantomEVo's Avatar
The Dynojets read around 15-18% more than the Dyno Dynamics, so the APC Evo would put down around 950whp on a Dynojet...
I think Pruven had both Dynojet and DD and came up with that %
But who cares what the dyno reads, its only a tuning tool.
Trap Speeds tell it all, 170mph is amazing. RWD drag cars usually go high sevens with 170mph traps.
Old Mar 28, 2006 | 12:19 PM
KOEvo's Avatar
Weight...
Old Mar 28, 2006 | 12:26 PM
C6C6CH3vo's Avatar
What material did you use to heat wrap on the hot portion of turbo (seen in the image)?
