yet another "first timer" thread
Old Apr 16, 2006 | 10:16 AM
money pit's Avatar
saturday was the first time in a long time i haven't had to work, so i figured it was time to put a pass or two on the car. this was my first time at the dragstrip with the evo, so i set my expectations accordingly. i had three runs, with the last being the only semi-decent run. at least now i have some idea how to launch. i expect to do much better next weekend if i can make it out.
best run:
60' = 1.798
1/4 = 12.81
1/4 mph = 108.17
i'll have to get another look at the timeslip when i get home later (yeah i'm working again, haha) for the 1/8 mile measurements. i'm definately not thrilled with the results, but i figure its a decent start.
mods are the usual BR stage 3 (272's) stuff with a walbro 255 and custom DynoFlash. see sig for video, haha. boost is 21 falling to 19.
i don't drag race much but it was pretty fun. hopefully next time out i can get in the 12.0 - 12.2 range. i don't think that is out of question. thoughts?
Old Apr 16, 2006 | 10:50 AM
dsmfan95's Avatar
I would expect a much higher trap with your mods. The time isn't that bad for the trap, but it seems like you should be making more power.
Old Apr 18, 2006 | 08:35 AM
money pit's Avatar
well i guess there isn't much to comment on in here.
my 1/8 et = 8.211
1/8 mph = 86.19
after comparing my time with others, i am disappointed in the trap speed. i thought it could hit 110 relatively easy. i guess i'll just try again this weekend.
Old Apr 18, 2006 | 09:16 AM
dayf's Avatar
Do you have an aftermarket clutch? Are you shifting into 5th?
That's a decent 60ft time.
Old Apr 18, 2006 | 10:59 AM
Warrtalon's Avatar
I just think it's slow shifting. Yeah, your mph is low, but you're about .3s off where you could be with that 60'. I had a rough time this past weekend with spinning all 4 off the line on a slick launchpad, but was running 12.4-12.6 on 1.75-1.89 60's with your same mph. I did my worst on the 1.89, which was a 12.68@108.5. The best was 12.47@109.1 with a 1.75, which still wasn't great, but you have room to improve with the shifting. I don't see 12.0-12.2 even being a remote possibility unless you find some MPH somewhere.
Old Apr 18, 2006 | 12:29 PM
money pit's Avatar
no, stock clutch. i'm not shifting into 5th.
yeah, i'm sure the shifting is less than what it could be. i definately have to improve that. perhaps i should shoot for a 12.5 and live with it. or get an alky kit. i told my wife i was done buying parts for a while too, haha (she knows better)
thanks guys.
Old Apr 18, 2006 | 01:09 PM
Warrtalon's Avatar
An alky kit would bump you up nicely, but with 303whp on the BR MD, you should be trapping well over 110. Instead of going with an alky kit right away, try tossing in some race gas and crank up the boost to 24-25psi next time.
Old Apr 18, 2006 | 01:32 PM
DRAG's Avatar
303whp on Dave's dyno and you are running 86.19 in the 1/8th...hmm. I'm running 85-85.5 and weigh 3450+ depending on gas.
I wonder what kind of power I am making stock? Gotta get on the dyno.
Old Apr 18, 2006 | 01:54 PM
money pit's Avatar
that's kinda what i was thinking. i'll see what some sunoco 110 and a few turns of the hallman will get me.
Old Apr 18, 2006 | 02:39 PM
Warrtalon's Avatar
Adding to that notion, I trapped 86 in the 1/8th on every run this past weekend, and I'm making 295-300whp uncorrected on a Dynojet. Sucky.
Old Apr 18, 2006 | 02:46 PM
1NastyEvo's Avatar
What's the elevation @ that track you ran at ?
