gt35r traps at 20psi and 92 oct
Old Sep 11, 2006 | 03:26 PM
Turbojunkie's Avatar
I went down the strip this weekend and was wondering what kind of trap speeds others with gt35r set ups are trapping at 20 psi. this is on straight pump and a solid 20psi. anyway ive ran TORCO and 24 psi and only gained like 1-2 mph. sounds weird to me. anyway, just trying to compare and check to see if these seem on target.
worst pass
1.98 60' ( i still suck at launching this big turbo)
1/8 7.88 @ 92.16
1/4 12.45 @ 117.4
most wer right in that range
best pass
1.81 60'
1/8 7.8x @ 92.56
1/4 12.34 @ 118.97
rember this is a solid 20psi on 92 oct. sound right?
Old Sep 11, 2006 | 03:28 PM
LancerevoIX2006's Avatar
worst pass
1/8 7.88 @ 92.16
1/4 12.45 @ 117.4
best pass
1.81 60'
1/8 7.8x @ 92.56
1/4 12.34 @ 118.97
I trapped my highest at 121 at 21 ...
11.7 =D
Old Sep 11, 2006 | 03:32 PM
SHIFTT IX MR's Avatar
11.7 =D
that is very fast.
Old Sep 11, 2006 | 03:40 PM
machron1's Avatar
Forgive my ignorance but why buy a GT35R and run it at pump gas boost?
Old Sep 11, 2006 | 03:43 PM
your ignorance is forgiven j/k. doing some bracket racing that day and find it way easier to be consistant with pump and low boost. this is what works for "ME". that is why i did anyway.
Old Sep 11, 2006 | 04:01 PM
machron1's Avatar
Ahhhhhhhhh i see now. Hey, next time you are at Red Lobster, try the fondu bread bowl but have them replace the fondu with lobster spinach dip. It's so good and filling that along with the buiscuits, you don't even need a main course lol. It's soooooooo good!
Old Sep 11, 2006 | 04:04 PM
LOL, i hate seafood, the only reason i go there is because the girl loves that shat!
Old Sep 11, 2006 | 04:08 PM
JohnBradley's Avatar
I hate to be on topic, but it seems something isnt right cause I ran 12.21 on stock turbo on pump. Shifting easy maybe?
Old Sep 11, 2006 | 04:12 PM
05r6's Avatar
how do you run 7mph higher and half second worst time then a evo with tbe-flash,
your traps will significantly move up and your times will significantly drop, if you learn how to drive your car.. it's hard to tell with those number's. go practice some more and post again.
Old Sep 11, 2006 | 04:15 PM
machron1's Avatar
That's dedication. I would never take a girl out for vegan dinner because I firmly believe salad is what food eats.
Old Sep 11, 2006 | 04:17 PM
Breakdown of my 12.21 pass:
60'-1.734
660-7.78
660-88.6
1/4-12.21
1/4-111.62
Old Sep 11, 2006 | 04:55 PM
PhoenixEvo's Avatar
Maybe cause a stock turbo is made for pump gas. A gt35r doesnt come alive with 18 psi. A gt35r on stock block with pump gas isnt gonna give u much. These trap speed #'s sound about right. But they et could be a bit lower per the trap speed. (A stock turbo is easier to get off the line then this gt35r on pump gas) Thus your faster et's.
Old Sep 11, 2006 | 05:12 PM
dont sweat it, i wont hold you over the fire for being on topic . Im not comparing my sh ity ets just trap speeds of other gt35rs on pump. fyi, ive ran multipule 12.0x and 12.1's on the stocker and pump also.
Old Sep 11, 2006 | 05:30 PM
PhoenixEvo's Avatar
What gt35r kit is this??? Also what kinda traps were u expecting? The highest i ever heard or a gt35r trapping on pump gas is 121 by LancerevoIX2006 who just posted above saying his trap (yes i dont know if he has a gt35r, because his profile says "GTXXXXR", so maybe he has a 3076 or somthing but "35" doesnt take 4 x's). Besides that the highest traps i seen on a gt35r kit pump gas stock block is 118ish. Maybe just being a 9 and able to advance timing a bit more then an 8 is playing a factor.. or maybe just one of those other things like, humidity, head wind, heat soak, All these things could vary your traps. But what traps did u expect or hear from other 35r kits on pump gas stock block on an 8?
Old Sep 11, 2006 | 05:37 PM
I was trying to see if im on parr with other 35r's. im running the slow boy 35r kit with the .63 hot side and .70 ar cold side. i do get some shift lag when i shift slow (which has a little bit to do with the low et). Im still working on my 60's they are *** right now. im sure if i was able to cut a 1.7 id hit 120 or close to it. im also running a flash only. no aem, exede, or anything like that. i feel good about the power its making. id definatly put the woop on a stock turbo as far as power to psi levels go. what kit are you running?
Originally Posted by PhoenixEvo
What gt35r kit is this??? Also what kinda traps were u expecting? The highest i ever heard or a gt35r trapping on pump gas is 121 by LancerevoIX2006 who just posted above saying his trap. Besides that the highest traps i seen on a gt35r kit pump gas stock block is 118ish. Maybe just being a 9 and able to advance timing a bit more then an 8 is playing a factor.. or maybe just one of those other things like, humidity, head wind, heat soak, All these things could vary your traps. But what traps did u expect or hear from other 35r kits on pump gas stock block on an 8?
