help me improve?
Old Apr 3, 2007 | 08:24 PM
thekuai's Avatar
help me improve?
im the car on the right...car on the left was a new s4
Old Apr 4, 2007 | 05:51 AM
mcwop23's Avatar
what kind of turbo do you have? 32MPH in the back 8th is freakin' crazy
Old Apr 4, 2007 | 05:53 AM
thekuai's Avatar
Turbonetics 60-1 HIFI
Old Apr 4, 2007 | 06:40 AM
Warrtalon's Avatar
Not much to say. Launch a little better and shift MUCH faster. I'm guessing it's bogging a bit between shifts and having to re-spool.
Old Apr 4, 2007 | 01:48 PM
NIevo's Avatar
Yeah, just work on the basics. What kind of tires are you running?
Old Apr 4, 2007 | 04:29 PM
thekuai's Avatar
bfgoodrich drag radials @ 25 psi
Old Apr 4, 2007 | 06:03 PM
KuRRu's Avatar
+1
Old Apr 4, 2007 | 06:15 PM
NIevo's Avatar
Might try dropping some air out of the tires. 25psi on drag radials is alittle high. What are you launching at? 1.7 60' is pretty high for drag tires.
Old Apr 4, 2007 | 06:16 PM
thekuai's Avatar
im pretty sure sean ivey set my 2step at 6300
Old Apr 4, 2007 | 08:27 PM
Sean@Iveytune's Avatar
something is going on with that slip, did you miss 2-3? or perhaps the 3-4. Starts out ok then slows then picks up. If you get a 4.6, and a 7.2 you should be runnin around 11.2, not bad. What RPM are you shifting at? try to keep it high as the car will fall off between shifts if you shift too low.
oh 6250 on the 2 step just checked.
Sean
Old Apr 5, 2007 | 07:30 AM
NIevo's Avatar
Good catch, didnt even notice the 1/8th mile times. When I ran the time in my sig I was almost 1 mph faster and about the same ET. Then you picked up 4mph and .1 ET in the back half.
Old Apr 5, 2007 | 11:39 AM
mike1023's Avatar
thats crazy his 1/8 mph is 92 and 1/4 is 123
then you look at my 96 and 120 lol im lamo
i can give you driving instructions if need, i will take ya out. yell at you and **** like a crazy instructior
Old Apr 5, 2007 | 07:45 PM
thekuai's Avatar
Sean
i hit every gear fine...i do believe I have a boost leak though....i trapped 125 at atco i have a shiftlight and shift at 7900
Old Apr 5, 2007 | 07:46 PM
thekuai's Avatar
i dont know how i could shift faster.....what is there besides push the clutch and rowing into the next gear as fast as u can?
Old Apr 5, 2007 | 08:49 PM
Warrtalon's Avatar
Well, some think they are fast and really are not. Here's my example:
http://bagelbitez.com/dcevoclub/Warrtalon/12.30.mpg
If you shift that fast or faster, then something is wrong with your car, but from the splits, it looks like you're falling out of boost on the bigger turbo between shifts.
