Bogging off the line
Old Apr 26, 2007 | 05:57 PM
WickedWhtMR's Avatar
Question Bogging off the line
The last time I went to the track I ran consistent 1.6 60ft. I dont know what it was on the "street" but it felt about the same. My 2step is set to 5,400rpm and builds about 6lbs of boost. Since the last time i launched the car I have added the flywheel/clutch package. I tried launching it several times today on a dead end road behind my buddy's shop. The car bogs every time... I have tried slipping the clutch and ive tried dumping the clutch. Any other suggestions?
Thanks
P.S. I also have never launched the car using the Greddy EBC. Only the DNA MBC
Old Apr 26, 2007 | 05:59 PM
Ultimate CC's Avatar
likely from the flywheel being lighter, up the launch rpm...
Old Apr 26, 2007 | 06:01 PM
evovin's Avatar
was ur 2 step set 5400 rpm before or after the clutch?
Old Apr 26, 2007 | 06:09 PM
it was set before the clutch package was installed... im a little concerned about upping the RPM on the 2step... im very fond of my transfer case... if it were your MR.. what would you raise the limiter 2? The clutch is a 6 puck ceramic with an exedy pressure plate and flywheel... im also a wondering why the car only builds 6lbs of boost on the 2step...
Old Apr 26, 2007 | 06:22 PM
Anyone?
Old Apr 26, 2007 | 07:19 PM
no one?
Old Apr 26, 2007 | 07:23 PM
rACerS's Avatar
Fond of your transfer case and 6 puck dont really go together And yes your now bogging because you went with a lighter flywheel. If you dont want to bog youll need to either raise your 2 step or slip the clutch more.
Old Apr 26, 2007 | 07:24 PM
DragNRacing's Avatar
I have an MR with an Exedy twin disc and launch the car from 5500 - 6500 depending on the track and have well over 300 launches on the car. The last time I looked at my logs, I was starting at around 7psi when I first started stuttering and right before my MPH changed from 0 - 15mph in the logs, I saw 20psi. The amount of boost you build really depends on how hard the cut is set on the stutter and the size of the turbo.
Old Apr 26, 2007 | 09:38 PM
stock turbo.... how do i build more boost... and what should i raise the rpm 2?
Old Apr 26, 2007 | 09:54 PM
NIevo's Avatar
I would say to raise it to 5800rpm's and go from there. If you still bog raise it alittle more. Also make sure your giving it alittle slip and not just side-stepping, that will save your t-case.
Old Apr 27, 2007 | 04:23 AM
Raising the RPM should give you some more boost. The other option is adjusting how hard the cut is. The AEM has options for this. I am not so sure about other tuning devices though.
The RPM will depend on the track, how fast you are slipping the clutch, how good your tires are, etc. For me, it is something that changes nearly every time I go to the track.
Old Apr 27, 2007 | 12:28 PM
ApexVIII's Avatar
ya you need to up the launch
Old Apr 27, 2007 | 03:57 PM
joeymia's Avatar
bogging can break your tcase easier than spinning tires...
Old Apr 27, 2007 | 04:00 PM
evovin's Avatar
^huh?
Old Apr 28, 2007 | 11:42 AM
supersnow's Avatar
when you bog, you put more shock into the drivetrain, by raising the 2 step to atleast 6000 rpm, you will spin the tires which save your drivetrain from the initial hit.
