Pump and Meth personal best. Buschur Power!
That's where my damn 1st gear comes into play. I did properly fix the boost issue and was placed 2nd in the brackets for AWD class. I line up with newly found power and blew out of 1st not once but 3 times!! I finally got back on it almost half way down the track and trapped 122MHP, from 2nd gear
I hate my first gear and hopefully, if I can ever get a hold of him, have Jon at TRE fix it.
Went to Import Atlanta yesterday and had a great time! It was a great ride down with friends from Topspeed in memory for a lost friend. Great cruise!
Still had issues with my first gear so I had PLENTY sloppy passes however, I did set a new personal record. I had NO access to VP Import so I would have loved to know what the time would have been. I was running pump and meth @ 21 psi! I was fooling with my boost controller and I thought I had turned it up and I actually turned it down. I should be running 32psi! I even missed second once but finally got it in and she took off! For the non believers I have the data log. The run is below:
60' - 1.623
330 - 4.501
1/8 - 7.168
MPH - 95.19
1000 - 9.350
1/4 - 11.176
MPH - 124.01
Thanks to Buschur for building and tuning this beast. Thanks to Doug from Topspeed for dialing in my two step and support at the track. Very excited to get some race gas in her and turn up the juice!
60' - 1.623
330 - 4.501
1/8 - 7.168
MPH - 95.19
1000 - 9.350
1/4 - 11.176
MPH - 124.01
Congrats on that awsome time!
What kind of tires did you have? Any spinning?
