1st time at the track, basically stock
Old Oct 15, 2007 | 11:42 AM
sloAZevo's Avatar
It has an invidia cat back. Thats all I know, it might have a flash because I can hit 7600 before fuel cut.
1st run ever launching an AWD car:
2.027 60'
13.652 @ 102.240
Second run was:
1.98 60'
13.62x @ 100.107
Third run was
2.0xx 60'
13.7xx at 98.xxx, it was my slowest run, I hung on to third too long.
They told me to slow down or go home because I didn't have a helmet after the first run.
I was shifting at ~7k-7.2k, the first run I don't even know what I was shifting at because the AWD launch scared the poo out of me lol. I'm used to 2.4s in a FWD car
Old Oct 20, 2007 | 05:42 PM
RenEvoIX's Avatar
u really really need to work on ur lonch... wot rpm r u lonching at..
Old Oct 20, 2007 | 07:14 PM
SickSilverNLow's Avatar
work on that launch bro.....you should get a slightly better time.
Old Oct 20, 2007 | 07:21 PM
596736's Avatar
Keep at it
Old Oct 20, 2007 | 07:29 PM
11secDSM's Avatar
Not bad for your first time in an AWD...def work on your launch as everyone else has stated.
Old Oct 20, 2007 | 11:02 PM
recompile's Avatar
Stock rev limiter is 7600 so that doesn't mean you're flashed
Old Oct 24, 2007 | 09:52 AM
calilancer02's Avatar
Not bad, I baby my **** too, I can't afford clutches. just knock off .5 from your time for baby your launches and you should have a pretty accurate guesstimate
Old Oct 24, 2007 | 10:34 AM
CrackerJackToy's Avatar
Wear a helment? WTF, for high 13s? They dont require a helment here until 10s.
Old Oct 24, 2007 | 01:48 PM
mcwop23's Avatar
nhra rules, under 13.99 you need a helmet, under 11.50 you need a rollcage, etc.
Old Oct 25, 2007 | 06:58 AM
fastrob691's Avatar
Were you running in Phoenix or Tucson? Those are pretty much stock times for that area, so on that note, good job, and the AZ tracks are strict as far as rules regardining helmets, etc.
