Trying to run better than an 11.6 on stock cams. Need input.
Old Apr 5, 2008 | 05:15 AM
TTP Engineering's Avatar
Be careful wih solid pulleys. I do not recommend a solid pulley. There is no such thing as a performance lightweight crank pulley for an Evo.
If you do anything, use a Fluidampr.
Old Apr 5, 2008 | 02:29 PM
Wiznaz's Avatar
We're in the same boat dude.. I think we've pretty much maxed the stock cams.. What do you think about head work/ported TB?
I agree that dropping the tranny for VIII gearing isn't what I want to spend my cash on. I think some proper weight reduction is good for ET but I don't think we'd gain any extra mph.
Just get cams
Old Apr 5, 2008 | 03:32 PM
RyuEvoIX's Avatar
Would a solid pulley be fine just for the track and then switch it back out to the stock pulley right after?
Old Apr 5, 2008 | 05:55 PM
I wouldn't bother with the solid pulley. It could have negative effect on bearings.
You would be better off bypassing the A/C with a shorter belt.
Old Apr 5, 2008 | 06:06 PM
fugiwara's Avatar
why taller tires increase trap speed?
Old Apr 5, 2008 | 06:08 PM
fugiwara's Avatar
TTP, I always see you selling the fluid damper, what is the benefit?
is it true the they are not going to make the aluminum fluid damper anymore?
Old Apr 5, 2008 | 07:52 PM
RyuEvoIX's Avatar
taller tire=taller gears. It's supposed to help if your running out of 4th gear before the end of the track.
Old Apr 5, 2008 | 08:07 PM
fugiwara's Avatar
thanks, I didn't know that before, so if I get taller tires, my tach reading would read lower than before?
and this will help me since I have 6 speed, which the 4th gear is shorter than 5 speed tranny?
Old Apr 5, 2008 | 08:23 PM
JohnBradley's Avatar
VIII 5 speed, 4th is 1.031:1 reduction with a 4.52 final drive
IX 5 speed is 1.091 with a 4.52 FD
VIII/IX MR 6 speed, 4th is 1.1:1 reduction with a 4.583 FD
The thing about taller tires is they are also generally heavier and adding weight in rotating mass is not ideal. Honestly I dont know that its alot cheaper to buy a new set of good tall tires than an VIII 4th gear, just less labor. The closer you keep your trap RPM (as you cross the line) to peak power or just a little past the better.
I am also with Scott, solid pulleys on an Evo induce alot of unwanted harmonics and can cause issues. This is a big problem with alot of import applications as they are just not designed to be run with a solid crank pulley.
Old Apr 6, 2008 | 07:09 AM
RyuEvoIX's Avatar
I agree with this statement but it is also possible to find equal weight or lighter tires of a taller size. I'm switching from stock size potenza's to 245/45/17 Nitto NT555R's which are listed as 2lbs lighter then my potenza's.
Old Apr 6, 2008 | 07:11 AM
SPEED's Avatar
Originally Posted by Most-Wanted
Be careful on the weights of the tires you are going with. pm me if you want some help on this. Rotating mass is a killer and especially on tires since it is the furthest point out. Raise the rev limiter or just swap the 8 3/4 gear in.
+1
Old Apr 6, 2008 | 07:20 AM
raiceboi697's Avatar
as TTP stated dotn worry about the pully as you have to shave 200 lps off the car per .10 of a second you wanna shave by pure weight reduction. is you get into the nickle and dime game of weight reduction for time in the 1320 you might wanna price AMS's carbon roof, carbon doors, a uncomfortable as sin drag seat, sellign your passanger seat, etc....
Old Apr 6, 2008 | 05:39 PM
fugiwara's Avatar
why don't you just get pair of camshafts?
Old Apr 6, 2008 | 05:42 PM
fugiwara's Avatar
I am very tempted to buy Fluidampr as TTP explained it to me very well, will I free some hp by having it?
Old Apr 6, 2008 | 06:22 PM
RyuEvoIX's Avatar
Not in the budget quite yet as I plan on porting the intake and getting a 65mm TB to tune it all in one shot.
