went to the track
Old Apr 7, 2008 | 05:21 PM
04evony's Avatar
went to the track
went to englishtown this weekend and got a couple of runs in. my best was 12.43 @113 with a 1.75 60". i was cold and no one was hooking up. i definitley could have gotten the 60" to like a 1.5-1.6. and my mods are intake, cosworth 272 cams, dc downpipe- testpipe, megan catback, reflash on a stock clutch. next time a think i can get it down to at least a 12.2 as long as its not to cold and i can get it to hook up
Old Apr 7, 2008 | 05:48 PM
Nad1370's Avatar
Nice run.
No boost controller? What psi?
Stock blow off valve?
Old Apr 7, 2008 | 05:53 PM
BGevoIX's Avatar
Not bad. From my experience, it's not that easy to pull a 1.5-1.6 60'. I would be happy with consistent 1.7 60' times. Either way, you should be good for low 12s with that 60' and trap speed. I ran a 12.16 @ 112.98 w/ a 1.78 60'. All in all, nice run. More practice will make your times even better.
Old Apr 8, 2008 | 10:48 AM
04evony's Avatar
ya im not fully used to awd i always drove rwd. i am controlling boost with a avcr and it set at 24psi
Old Apr 8, 2008 | 03:29 PM
Ralliart_on_LSD's Avatar
blow off valve makes a difference?
Old Apr 8, 2008 | 04:10 PM
04evony's Avatar
blow off valve makes no difference. anyway i have a synaps bov. i was also shifting at 6500 because when i first got dyno my power started droping off at 6700
Old Apr 8, 2008 | 08:52 PM
mcwop23's Avatar
shift at 7K
Old Apr 9, 2008 | 04:49 PM
Boltz.'s Avatar
FCOTM Winner
BOV's make a difference because the stock unit leaks at high boost. You are shifting WAY too early.
Old Apr 12, 2008 | 05:08 AM
04evony's Avatar
but if my power band ends at 6700 why would i go out of my power band and shift at 7000
Old Apr 12, 2008 | 08:14 AM
supersnow's Avatar
you might have a leak them...with your set up you should see your peak whp at 6900-7100 mainly because of your cams. Probably the tune?
6700 is too early in those cams.
Old Apr 12, 2008 | 10:35 AM
mcwop23's Avatar
shift at 6700 and you drop to an RPM where you make alot less power
Old Apr 14, 2008 | 11:18 AM
project VII's Avatar
good to know, thanks
Old Apr 14, 2008 | 11:19 AM
my power band kinda stop around 6700 too
Old Apr 14, 2008 | 10:08 PM
supersnow's Avatar
don't forget to account for torque multiplication by gears...ideally you want to run your lowest gear as long as your torque curve allows you.......peak whp means nothing, there still hundreds of RPM after your peak where your lower gear will take you faster than your next gear.
For example; if you peak at 6700 RPM with 330whp but at 7200 rpm you are still making 300whp then your first gear will benefit you faster than your 2 gear at 320whp for example due to gearing:
300 whp (rpm /torque) * 4.53 (Final gear) * 2.909 (1st gear) > 320whp *4.53*1.944(2nd gear)
3953>2818
Old Apr 15, 2008 | 02:47 AM
BURNALL_4's Avatar
Hes right, you should be shifting at 7000-7200.
