Ix Rs 11.0@123
Thanks guys, 60's should come down a little more. Just lost another 100 pounds and added a small brake kit for the rear
Thats a whopping 17 pounds of rotational mass lost. Hoping to get back to Moroso on Wed or Fri of next week. They are closing for 3 months
Technique is 6811 rpm launches on a light car. I just quick slip it, no dumps. I lift to shift every gear as well.
u upgrade values? mine is stock... and no porter intake and TB 65mm...
last time i ran 12.3 with stock now i upgrade cams and wga so i hope high to low 11s.. im try out tomorrow drag..
sweet! ill hit track tomorrow hope see 11s... so take me praticces... i set my 2 step at 6000rpm... or 6200... and my redline shift at 8000 but ecu set 8212rpm..
i need work on my 60 ft.. last time i did 12.3 and 12.5 now with new set up with loose wga arm took me stuck 12.8 and 13s... so i tight wga arm last night.. psi still 25 cuz i turn down my mbc to 25...
so i hopefully 11s to high 11s
so so bad for me today. i got run to 12.3 and try to get high 11s but bad news..
check out
https://www.evolutionm.net/forums/sh...d.php?t=344712
check out
check out
check out
