Suspension/chassis setup from a track car to a drag car.
I track prepped Viii thats getting tuned on E85 next week and I want to take it out and drag race it just for ***** and giggles. Right now the car is on Ohlins vishnu/gerrard specs, corner balanced, rear sway full stiff, -3.2fr camber, -1.2 rr camber.
So Im wondering what would be the easiest misc stuff for me to do. Alignment, sway bars, strut tower bars etc. What can I do to improve my times? I only plan on making one trip out so I want to make the best of it.
Ride height doesnt really affect it much. You can leave it alone. I ride slightly lower in front, but nothing specific. I run without sway bars as they do nothing but add weight if your going straight. I have removed both front and rear. And no strut bars either.
All about weight transfer; static camber is far too negative if you're concerned about the launch at the drag strip. At your static camber of ~1.2 degrees camber, upon launching, (weight transfer aka rear squat) would probably net you closer to a ~2.0 degrees if not more out back resulting in a much lesser contact.
The idea is you want to start off with as little camber as possible so when you do squat you still retain optimum grip. I would suggest starting at 0degrees camber out back if not 0.5degree POSITIVE camber. Try it out coupled with proper tyre pressure and see what your 60' does.
ps. agreed any chassis stiffening braces would diffuse your overall goal.
HTH.
HTH.
HTH.
HTH.
DSMolition
34
Aug 1, 2017 07:55 AM
AJR-Coco
12
Nov 2, 2011 11:20 PM
teamsprock
19
Jul 29, 2008 03:00 PM
but I'll be sure to knock some camber out the front.
