Dogboxracing Evo showdown with vid
Mike
Alex it was a pleasure to finally meet you. You guys made us proud. Your car is Bluetiful
Glad to see the new Sequential Ignition is doing it's job. The car was very consistent and sounded clean.
There is no doubt if track prep were a bit better it would have gone into the 8's even with the track temps the way they were. It was HOTTTT, and humid.
Congrats on your 3rd place.
Thanks it looks like you guys are on the right track. Few bumps in the beginning like we all have. You guys seem like you guys have some fight left in you and I am sure you will reach your goals.
Also like to thank all for the positive words. It keeps us going. This car was built with a lot of love, time, and help. Although going fast is our goal we also paid close attention to the details.
If any one has any tips about the suspension setup feel free to chime in. we will be working on the 60 and making it go straight. When that happens we can go full power about 80% now.
Car is awesome, make sure your alignment guy is up to snuff! When you make that kind of power its a major thing to get right. Can you guys post up what it costs for a clutch change and maybe your other services? Do you offer tuning?
i still couldnt get over the fact of how meticulously built that car was when i was there..im soon going to need a clutch change and some damn oil leak checked..so +1 on how much you charge for that..I've been hearing you are the most reasonable, if not, cheapest, but still do top notch work.
Track was prepped.Problem is too many cars with street tires screw up track.That and bad suspension setups.I willing to bet my rwd 90" wheelbase Toyota Starlet would run low 8s like it always does with track the way it was on sunday.These high hp evos definately need better suspension tuners.
Congrats guys on doing so well! In our round I was able to get the car out of the hole under boost which was a suprise, but had to lift 4 times on the back half of the track and watched you pull away hard. It was nice to meet you guys.
The track was not at it's best.. PERIOD...
Anyhow.. Congrats to Dogbox.. You worked hard on that thing and it's finally starting to payoff.. Now it's time to get that thing in the 8's...
The track was definitely in poor shape. The groove was very narrow and it just wasn't hooking anywhere. My best 60' of the day was 1.43. This is the first time I've been to a track in the last year that I wasn't in the mid-1.3's or better (best 1.282). My 330' times were off 0.3-0.4s from normal, 1/8 was off 0.4-0.5s, and I was spinning badly at the top of 2nd gear on every bump. I'm used to tuning my car to the track conditions, but I had everything fully turned down here and was still out of my normal window for test and tune no track-prep radial-tire nights at my local track. I was pulling a max of about 1.2G's and I'm used to 1.45G's on a normal track and 1.6G's on a good track. Make no mistake, the track was NOT hooking.
It was good running you guys in the semi's, I kept looking over and waiting for you to come blowing by! That was definitely the highlight pass of the day for me. You have a beautiful car and that was a pretty darn good pass for the conditions!
Kevin
Kevin
I wouldn't be so confident. The track was slick on the top end. My car runs within a tenth on every pass and sixty foots in the 1.2s. I was getting 1.5-1.7s and had to lift at 1000 feet on every pass. This is RWD with 29x13.5" slicks.
Next year consider Norwalk.. Track was sticky...
I've been to the SO since 2002, so I do know how the track is prepped there. The 60 foot is not as good as my local track but the rest is better. I chose to go to the Showdown this year and I'm still happy with that choice, I had an awesome time with the guys that went there. Track prep will be an easy fix for next year. If the events happen on different dates I'll be at both. That being said I'd hate for this thread to get poluted with the same old event vs event stuff, it wouldn't be fair to the OP.
Great.. I would love to see some more of the Quick RWD cars at the SO next year since it will be on different dates!! take it easy..
Mike
