Help diagnose my slip
Old Sep 8, 2009 | 02:08 PM
Paintballguy's Avatar
I'm on the left obviously... Anyways mods:
Stock motor
80mm fpred on 93 @ 24-25psi
The car bogged pretty bad on the launch. The 2 step is set at 6k, and I had the tires at 20psi.
Old Sep 8, 2009 | 06:17 PM
BluEVOIX's Avatar
Wow I thought my situation was bad.
My two suggestions are to do a Boost leak check and if possible also to do a compression test.
Old Sep 8, 2009 | 06:56 PM
StreetThisEvo's Avatar
Just a low 1.6 sixty would get you in the high 11's. MPH is ok but I think with better driving (better shifting/launch) you'd be mid 11's or so.
What does the car weigh with driver?
Old Sep 8, 2009 | 07:03 PM
Right around 3370 lbs.
