Black Mamba Evo IX does 10.0 @ 147mph!
Thanks a lot for the comments everyone...
It was a midnight madness event at the track..so prep wasn't the greatest. On the 10.0 pass the 60 foot was 1.78 I believe. I lost the timeslip
...will be calling the track tomorrow see if they can retrieve the info for me.
MPH wise I believe at the 1/8 mile I was @ 109. I feel with a solid 111-114 in the 1/8th I should hit a 150+.
The car weighs in @ 3150 with me in it and the cage. It's an Autopower 6-point bolt-in steel cage. Not light by any means when paired with full interior. The bolt-in cage is needed for the track here.
Peak boost was in the 4th gear shift...hit 41psi of boost...it held mostly 38-39psi through the gears.
The 6765 feels great compared to the other turbos...timing is still relatively conservative and AFR's were in the mid-low 11's.
I'm thinking of making it back out to the track the following Wednesday..I'll be changing out the 272 exhaust cam for a 280 one..see how that works out. And practice my take offs as well!
...will be calling the track tomorrow see if they can retrieve the info for me.MPH wise I believe at the 1/8 mile I was @ 109. I feel with a solid 111-114 in the 1/8th I should hit a 150+.
Thanks for all the extra info it seems a 9 sec pass is right there w/ just a little better launch congrats once again and good luck on your next outting
Jorge, what can I say besides I humbly bow down to the only Black Mamba in Texas other than my own? She certainly is moving down the track with some bad intentions. Unfortunately, I might not get to see her in action personally as I'll be moving to Arizona shortly after I return to Texas from Iraq. I'll certainly stay in touch and even make the drive to 'ole San Antonio before I head west to finally meet you and the crew. Crack that nine-second mark and quit joking around!
badhabit90
38
Nov 24, 2007 04:58 PM
