first time at the strip
Old Jun 6, 2010 | 10:02 PM
daniel577h's Avatar
first time racing the evo since Ive bought it.
my traps seems a ltitle low for my mods which are.
helix dp, works hi flow cat, rsr exhaust, works drop in air filter and brain flash p2 also have BC 272 cams installed
car is a 05
heres my times since i dont have a camera at the moment.
R/T....... 219
60'....... 1.836
330'...... 5.501
1/8........ 8.545
MPH..... 79.44
1000......11.192
1/4.........13.387
MPH......103.24
What do you guys think? maybe launched to softly?
Old Jun 6, 2010 | 10:05 PM
AngryEvo8's Avatar
What is the two-step set at? Maybe raise it a bit and cut down that 60ft a little.
High 12's or 13flat would be in your future! Keep it up!
Old Jun 6, 2010 | 10:30 PM
daniel577h's Avatar
launch control was about at 6200 with the works brain flash. i slipped the clutch i think a little bit to long. i got a fmic and piping along with a boost controller, got to get into the 12's!
Old Jun 7, 2010 | 12:24 AM
xcelr8's Avatar
I would think with cams and bolt ons you should have trapped 110-115ish but idunno
Old Jun 7, 2010 | 06:42 AM
iicemanr6's Avatar
looks alot like what i got on my first time to the track. I dont have cams or a flash though. Everyone told me that its just going to take practice to get the launchs down and that will drastically help the end result.
I know when i was at the track i could hold 3rd almost til the line if i tried to run it out, but wasnt as fast if i shifted closer to the redline than well into it.
Old Jun 7, 2010 | 06:45 AM
dsmfan95's Avatar
Your driving doesn't seem too bad, although it does look like your car is underpowered for the mods. There are many people, including myself, that have went faster completely stock.
I would run a few tests (boost leak, compression, leak down) and make sure everything is completely healthy, then see about a full custom tune.
Old Jun 10, 2010 | 09:50 PM
daniel577h's Avatar
i did a boost leak test today and found 2 injector o rings leaking and the throttle body hissing, but do these really hurt performance that much?
Old Jun 10, 2010 | 11:11 PM
Boosted Tuning's Avatar
Yes. Boost leaks can hurt performance and transient response (ie how quickly boost build back up after a shift), which both kill times and traps.
Also the cat isnt helping. The BC cams are known for not bring the best. Same with the WORKS flash.
Also, this is on CA 91oct correct?
Old Jun 11, 2010 | 12:36 AM
daniel577h's Avatar
yeah 91 octane. Ive been thinking about swapping the cams for some kelfords 272 and getting a retune, just haven't decided if i want to go back to works or try gst...
Old Jun 11, 2010 | 02:02 AM
xcelr8's Avatar
My vote for gst. even without new cams. Fix all your leaks and retune.
Old Jun 13, 2010 | 09:49 PM
daniel577h's Avatar
i wonder if i could run 21 psi on 91?
