Tire psi
Tire psi
I was curious as i have heard conflicting advice on this with slicks, ive heard to have the rear with a little bit less psi by a lb or two. ive also heard that the psi should be the exact same in all the tires. Hopefully someone can give me a little advice here to save me from unnecessary passes on my slicks
I use the same in front and rear, around 13 psi on hoosier drag slicks. Some people said it would be better to have a little more in front to avoid braking down at high speeds (because front is heavier) but we never tested it. If anyone else has some experience, pls share.
