Top 20 Fastest/Quickest Stock Appearing Turbos for 2011
Old Feb 17, 2011 | 11:59 AM
  #31
fabcas311's Avatar
here's one of my run
60'........1.828
330.....5.211
1/8.....7.884
mph.91.77
1/4........11.996
mph.....121.57
but my best run was 11.5@123mph
i misplaced the slip.
60'...1.8
330....5.12
1/8...7.42
mph.....93.69
1/4......11.534
mph.......123.67mph
street tires,stock tire psi..launching at 4500 rpms
i tried the launch control but car would just go sideways and time was in 12's.
e85.with some gear lockout issues!
Old Feb 17, 2011 | 12:04 PM
  #32
fabcas311's Avatar
^^btw Track Elevation: 96 feet
temp: 77 degrees
Old Feb 17, 2011 | 12:22 PM
  #33
06MREvo's Avatar
^^^Nice job man! Mind posting a quick mod list, I know most of your mods but other people don't. Did you ever get on a dyno yet or just VDR? What were your VDR results again? Try and find the 11.5 slip if possible or take a better picture of the 11.9 slip, thanks man! Ill update the list later...
Old Feb 17, 2011 | 02:11 PM
  #34
fabcas311's Avatar
copied from jorge post:
Evo VIII GSR
HKS 7460R turbo
Shearer 02 Dump Housing
Kelford 272 Cams with springs/retainers
ETS Intercooler and piping
Forge BOV
megan ex mani
hks intake
megan dp/tp
agency power ti exhaust
Hallman Pro MBC
FIC 1050cc injectors/Walbro pump
ACT street strip clutch/HD PP
Tephra V7 Dual map/switch tuning for 93/E85
Stock porting/stock block
VDR stats:
Weight: 3263 + 280 occupancy weight (I weight 240, rougly 40lbs of tools/parts in car)
Tire Diameter: 25.7 (Pirelli Rosso 245-40-18 on Rota P45 rims)
Gear: 3rd
Outside temp 50+ degrees
Graph shows the 3rd gear pull on E85 with a 29psi spike of boost holding 24psi to redline. This is one heck of a turbo, very fast spool with great top end.
Dynojet 1.09 correction, the other with the VDR uncorrected numbers.
Old Feb 17, 2011 | 02:30 PM
  #35
fabcas311's Avatar
im going back at the track later on or tomorrow with some better tires.
ill post some slips if i will do good!lol
Old Feb 17, 2011 | 03:35 PM
  #36
Turbojunkie's Avatar
Nice mph outta that turbo. Yeah, a 1.5x and your in the 10's . What afr's are you running up top?
Old Feb 17, 2011 | 03:37 PM
  #37
fabcas311's Avatar
my gauge reads consistent 11.3-11.6
Old Feb 17, 2011 | 05:42 PM
  #38
fabcas311's Avatar
just came from the track!!!.....whhhhhhoooooooooaaaaaaaa!
i tried to play a little bit on the tire pressure..... tire pressure set at 20psi finally able to use my 2 step!lol....no lock out issues!!!
heres my best pass!...i dunno but the slip dont have the 1/4 mph?????.......
r/t...........252
60'.....1.670
330.....4.705
1/8.....7.227
mph......97.58
1/4...11.248
mph......???????
Old Feb 17, 2011 | 05:50 PM
  #39
wizzo 8's Avatar
Even though its awd tire psi still makes a huge difference. I personally run 18psi
Old Feb 17, 2011 | 06:02 PM
  #40
fabcas311's Avatar
yes i think it was around 18-20psi it was dark. i only had a cellphone light!
Old Feb 21, 2011 | 06:56 AM
  #41
06MREvo's Avatar
hey fabcas311...put your track times in the correct format like in the OP and Ill add you to the list...
Screen Name - Date - Shop Affiliation - Evo Generation - Engine/Turbo Setup - ET/MPH
Old Feb 21, 2011 | 08:44 AM
  #42
fabcas311's Avatar
[QUOTE=06MREvo;9094352]hey fabcas311...put your track times in the correct format like in the OP and Ill add you to the list...
COOL!
Screen Name FABCAS311
- Date 2/16/11
- Shop Affiliation JMS RACING
- Evo Generation 2003 EVO 8
-Engine/Turbo Setup 2.0 stock block,stock porting, hks gt2 7460r
-ET/MPH 11.248 mph?????? it didnt show in the slip..but i would guess with my previous traps 123-125ish
fabiene
Old Feb 21, 2011 | 08:50 AM
  #43
06MREvo's Avatar
[QUOTE=fabcas311;9094643]
COOL!
- Date 2/16/11
fabiene
Thanks but still not really in the correct format...haha...here check out the 2010 list...
https://www.evolutionm.net/forums/dr...os-2010-a.html
Old Feb 21, 2011 | 09:27 AM
  #44
fabcas311's Avatar
Lol!
Old Feb 21, 2011 | 09:30 AM
  #45
fabcas311's Avatar
fabcas311 / 2/17/11 / JMS racing / evo 8 / HKS gt2 7460r / stock block,kelford 272's / e85,stock ecu /street tires / tuned by jorge @ jms racing / 11.248 ET
