BEST RIM AND TIRE COMBO for DRAG
I have a 2008 evo X making about 600whp and the wheels i have on are not good for drag racing there a 18x10.5 rim and a 275/53/18 size tire and i know for the track I'm going to need something more suitable for drag racing.
i was going to get a 17inch evo 8 rim but they don't fit evo x front breaks are much to big.So I'm forced to get a 18 inch rim but my question is what would but the best TIRE and best 18 inch(size) rim to buy
i was thinking of getting a rota 18x9 or 18x8.5 to keep the wheel skinny and Micky Thompson or Hoosier brand slick but what do you think is the best set up for DRAG? Track use only.
you need to go through the forum and read threads. There is a TON of wheel and tire threads here....I would say run rpf1(cheapest), ce28($$$$), or tc105n(between 1700-2000) with m&h drag radials
thanks a lot man ill look around and check, no luck yet but i will keep looking
I could of sworn I read somewhere on here that you can install EVO 8/9 Front brembos on an Evo X... if that is true, then you would be able to run a nice 16" rx7 slick setup with a 20mm spacer...
Could you point me to some people that have had good results with the 17" m&h slicks ?? I'm so close to buying them but can't find people to give me a 60ft time or some real data.
