Videos of EVO vs Modded WRX and MazdaSpeed Protege
Originally posted by Lowness
did you get the mail-in flash or was it a custom flash?
Originally posted by ev8sive
What is your boost set at?
I was only boostin 17-18psi and trickling down to 15-16 due to the Muffler Delete pipe. I have since added a MBC, which I have set to 20psi but not have taken it to the track yet
Originally posted by EcrsEvo
nice run, but work on your reaction, if you fix that a lil your 1/4 will improve drastically and the mazda wont be anywhere near you
Originally posted by Gleason
dont most drag strips take the times from where you cross the line instead of reaction time?
You are correct. Reaction time has nothing to do with 1/4 time. The timing does't start until you cross the beam of light. I could sit there for 2 hours then launch and pull the same 1/4 time.
Originally posted by TygerStile
Nice run against the wrx. I'm guessing he's running a stage 3 setup.
The WRX owner has since added a huge FMIC
He's trying to keep pace with me
Ariel_Evo
Aug 23, 2004 05:26 AM
boost, controller, de, evo, hood, mazda, mazdaspeed, mitsubishi, modded, protege, scoop, speed, sti, videos, wrx
