Toyo R888
Old Oct 9, 2012 | 01:30 PM
W2J's Avatar
W2J
Toyo R888
are these any good for the 1320? looking for something to mount on a 17x 9" wheel, looking for something to grip better than street tires but I do not want to shock the drive train too much like a full slick let me know.
Old Oct 9, 2012 | 03:03 PM
jonzie04's Avatar
toyo r888 is going to shock the drivetrain A LOT harder than a slick. they're pretty stiff. they work okay for auto cars but will wheel hop like a **** on a stick evo. what are you looking to do with the car. have an extra set of rims and tire to use for the track or dd on the new tires and go to the track occasionally? if you dd it i would say an r888 would be superior to a slick/drag radial/bias ply etc. but if they are an extra set of rims i'd look into the 17" m&h slicks.
Old Oct 9, 2012 | 03:18 PM
chu's Avatar
chu
R888 is a road racing tire. Usable for drag, but not ideal.
Old Oct 9, 2012 | 06:14 PM
W2J's Avatar
W2J
Thanks guys I'm only going to use it for the track on a set of spare rims, what about Hoosier 245/45/17" road racing dot tire is that any good? I'm seeing the Drag Radial Racing DOT is cheaper than the road version which one if any should I go with?
Old Oct 9, 2012 | 06:18 PM
W2J's Avatar
W2J
BTW I trapped 137mph this weekend with a terrible 12.2ET and a 2.50 60ft, hence the reason for me looking for a better tire.
Old Oct 13, 2012 | 12:11 PM
Ang Wen Yan's Avatar
Look into M&H 17" Slick
Buschur Racing carries it
Old Oct 13, 2012 | 12:19 PM
itsmrrizz2you's Avatar
go with the m&h 17" drag radials from buschur like the above member said... and 137??? damn you need to get that 60 down that trap speed is good for 10's all day
Old Nov 4, 2012 | 09:16 AM
94AWDcoupe's Avatar
wow you need driver mod, not better tires. no tire is worse than 1.8 capable on an AWD car.
Old Nov 14, 2012 | 07:48 AM
W2J's Avatar
W2J
Thanks guys I ended up buying some hoosier DR 245/45/17, will keep this tread updated with new results, BTW what tire pressure should I run in these 24psi? please keep in mind I'm still on the stock drivetrain.
Old Nov 14, 2012 | 12:24 PM
caLi4G63's Avatar
Depending on track conditions, I'd day start at 20psi and work your way down. There isn't a set pressure that works for everyone. Good luck and let us know your results.
Old Nov 15, 2012 | 08:26 AM
Pizzamangtr's Avatar
Not all awd cars. Track prep could be real crappy.
Old Dec 10, 2012 | 10:18 AM
W2J's Avatar
W2J
ok guys tried the Hoosier's and I got the 60ft down to 1.774, the track was not a bit damp as well and the tyres was hard so I would say these tyres ROCK!!!!!!! I will start to play with the tyre pressure a bit to improve.
Old Dec 18, 2012 | 03:10 AM
BURNALL_4's Avatar
that's a good improvement. you still got some time to shave off.
yellowevo82
15
Sep 23, 2016 11:06 AM
tommiti
Jul 22, 2016 11:27 PM
Locdizzel
Jun 2, 2016 07:26 AM
Kreeker
16
Sep 22, 2015 08:03 AM
Nespeed
Oct 23, 2013 05:25 PM
