Fist Time at the track 10.9 @ 130 MPH
Hello Evom,
I finally decided to take my car down the track on Wednesday night. I Drove 1 hour to get to the track and run a few passes. This was my very first time at the track and I think I did pretty decent considering I was nervous as hell plus I was on street tires
2006 evo 9
Built 2.0L/ Wiseco 10:1/Manley TT rods/ARP Main/ACL bearings
Unported Head/ Gsc 274's cams/Arp studs/ Supertech dual springs & retainers
FP Black with 25psi waste gate (JB) TUNED @ 35PSI
Buschur Ported Exhaust manifold
Custom downpipe with O2 dump / Custom 3" aluminum exhaust
Custom Dual walbro 400's/Fic 2150's/Fuel lab FPR/Perrin Fuel rail /-8 feed/-6 retun (e85)
stock tcase/stock trans with ev8 3rd and 4th
Exedy Triple disc clutch
Buschur Mustache bar /rear diff support brackets/crossmember /shifter bushings
Buschur Licp & Uicp
Buschur ported IM & 65mm TB
Custom oil catch can with Stm fittings
tuned on speed density with stock ecu (tuned by me)
Tein super street coilovers
Sorry for the bad camera quality , I need a GoPro ASAP
I've never taken the car to the dyno therefore, I have no idea how much power its making. Im assuming it's makes more than 550 whp.
2006 evo 9
Buschur Licp & Uicp
I'm just finishing a few things up this winter and off to the track this summer. Practice the launches and that car has a 10.5 in it EASY! it's all in the 60'
weight reduction list
1- buschur front crossmember
2- buschur mustache bar
3- buschur diff support brackets
4-tein coilovers
5- Custom 3" aluminum exhaust made by me
6- Removed sound deading and firewall mat
7-Removed spear tire, jack ,tools, rear mat and wood board.
8- Eliminated rear wiper motor assy
9- windshield wiper fluid tank
4-tein coilovers
my Fuel system is custom made by me.. i was able to fit two walbro 400s inside the factory tank with custom bracket. -8 feed -6 return.
injector duty cycl 49 percent at 35psi which is great enough fuel for more power
4-tein coilovers
4-tein coilovers
Nice times, what kind of rpm's are you turning through the lights? My motor let go just after my 11.3 pass so i'm building it this spring. I know the car had 10's in it but it wasn't in the cards that day i guess. Still unsure if i want to stay with the 2.0 for the rpm's or go with the 2.3-2.4 for the quicker spool.
