drag launch
Old Jul 12, 2004 | 06:18 AM
srd_evo's Avatar
drag launch
im freaked out about launching my evo cuz of the horror stories. what is a good rpm to launch the evo in??? i dont wanna go crazy but i dont wanna lose to a g35c like a couple weeks ago. =(
i heard some launch their cars at 6k =O!!! and get high 12's
thanks
Old Jul 12, 2004 | 06:25 AM
Rollaway's Avatar
depends on the mods.. stock id launch at redline and slip the clutch till it hooks than i dump it... with around 350whp id slip the clutch at 4k rpms... now i slip the clutch at 5100rpms and slip it all through 1st and some of 2nd(i have a very strong clutch)
best 60ft was 1.63 and ave mid/high 1.7s... now i shoot for 1.9s so i dont break any drivetrain parts
Old Jul 12, 2004 | 06:30 AM
srd_evo's Avatar
wow.. so at a dead stop i should redline my car and drop it when the light turns green?? my car is stock.
thanks
Old Jul 12, 2004 | 06:31 AM
James's Avatar
what? I love the G35 2 door and 4, but you lost to them. what happened. I raced a couple the other day, fully loady with brembo's and all, and i kick the crap out of him. I didn't even need to drop it. i just started off like i normally do. he even got a jump on me. i would hate to see how bad i would beat him if i droped it about 5 to 5500 rpms.
well good luck next time you see him and kick his a$$
later
Old Jul 12, 2004 | 06:32 AM
James's Avatar
hey man my car is stock too, just don't do it to often, the stock clutch is not the best one to have in an evo
matt55's Avatar
thanks
NOoo , reread what rolloway typed .
Old Jul 12, 2004 | 07:02 AM
srd_evo's Avatar
call me an idiot but im still confused =(...
what is a good rpm to launch the car at a dead stop??? i dont know what slipping the clutch means
please help! cant stand to lose to another "pretty boy" car =P
Old Jul 12, 2004 | 08:07 AM
watchout's Avatar
It means you don't just sidestep the clutch pedal, you ride it out a little while applying the gas. There is a fine line to doing it right, You don't want to burn the hell out of it nor do you want to drop it to fast, just practice a little, you will get it.
Shane
Old Jul 12, 2004 | 04:53 PM
Audi2ptzero's Avatar
thanks
There is more to it then just high rpms and the clutch. Launching a AWD turbo car is a little harder then most think it would be. Since it is a turbo car you want to bounce the rpms up and down to get the turbo spooling, this way when you do launch the boost will come on real quick and reduce the lag. Doing it this way and you can launch at a lower rpm then holding the rpms at a set level. You dont have to ride the clutch if you do it right, you will have to ride the clutch if you do it WRONG and cause the car to bog. If you bog the car alot you can raise your tire presssure up to 45 lbs to give less traction and allow you to put less pressure on the driveline. I have launched a few cars and did so without any time in the car before launching it hard.
