So close to 11's
Race gas 25>21 psi
60' 1.72 330' 5.00 1/8 7.72 MPH 88.18 1000 10.08 1/4 12.05 MPH 114.02 Pump gas 23>20 psi 60' 1.80 330' 5.12 1/8 7.87 MPH 88.14 1000 10.26 1/4 12.27 MPH 112.60 All runs are with the stock airbox and filter. Race gas runs were running 11.0 a/f ratios so there's a little room for improvement next time. |
Nice runs.
Knock off a little more on your 60' and you should be there. How's those twins feel upon launching? . |
Originally Posted by Nad1370
Nice runs.
Originally Posted by Stinkapuss
I love this twin disk. Only problem is it grips so hard I spin all fours constantly. Today I had 9 runs and spun 1st every time.
Originally Posted by Evoryder
i spin 1st too... lol .... gotta slip a little more and then mash....did you mess with your tire pressure? it helps
try launching at 5500 w/out 2 step...6 is pushing it...transfercase don't like too much
nope...i yet to try a 2 step...but i'd definetly not want it @ 6k .
To me, the times respective to the MPH are indicating quick shifting, one more true power adder required for the 11's
I was quickly slipping the clutch about 3/4's of the way and then dropping it right at the end, it was hooking up pretty well......Launch control is the only way to go!
Stinkapuss where you WOT shifting? I would recommend your drop your tire pressure to 22-23psi even with the Advans. It should help your 60' and modulate the clutch if needed to keep the traction. |
I do a partial lift shift. |
{thumbup} Good job bro.You can do it {thumbup} 11s r right there :cool:
Yup, I say next time out you hit 11's for sure!
| All times are GMT -7. The time now is 11:23 AM. |
