So close to 11's
Old Mar 4, 2006 | 07:03 PM
Stinkapuss's Avatar
So close to 11's
Race gas 25>21 psi
60' 1.72
330' 5.00
1/8 7.72
MPH 88.18
1000 10.08
1/4 12.05
MPH 114.02
Pump gas 23>20 psi
60' 1.80
330' 5.12
1/8 7.87
MPH 88.14
1000 10.26
1/4 12.27
MPH 112.60
All runs are with the stock airbox and filter. Race gas runs were running 11.0 a/f ratios so there's a little room for improvement next time.
Old Mar 4, 2006 | 07:26 PM
Nad1370's Avatar
Nice runs.
Knock off a little more on your 60' and you should be there.
How's those twins feel upon launching?
Old Mar 4, 2006 | 07:43 PM
Stinkapuss's Avatar
Originally Posted by Nad1370
Nice runs.
I love this twin disk. Only problem is it grips so hard I spin all fours constantly. Today I had 9 runs and spun 1st every time.
Old Mar 4, 2006 | 07:45 PM
Evoryder's Avatar
i spin 1st too... lol .... gotta slip a little more and then mash....did you mess with your tire pressure? it helps
Old Mar 4, 2006 | 07:49 PM
Stinkapuss's Avatar
Yes, tire pressure was 26 psi front and back. I'm on the stock advans so I didn't want to go any lower. My engagement from the 6k 2-step is freaking brutal.
Old Mar 4, 2006 | 08:10 PM
Evoryder's Avatar
try launching at 5500 w/out 2 step...6 is pushing it...transfercase don't like too much
Old Mar 4, 2006 | 08:29 PM
Stinkapuss's Avatar
Did you get a 6k 2 step with your flash?
Old Mar 4, 2006 | 08:30 PM
Evoryder's Avatar
nope...i yet to try a 2 step...but i'd definetly not want it @ 6k .
Old Mar 4, 2006 | 08:59 PM
Warrtalon's Avatar
It's not brutal unless you dump the clutch, which I don't do when using the 2-step.
Old Mar 5, 2006 | 02:55 AM
C6C6CH3vo's Avatar
To me, the times respective to the MPH are indicating quick shifting, one more true power adder required for the 11's
Old Mar 5, 2006 | 06:50 AM
smoothmarine187's Avatar
Veteran: Marine Corp
I was quickly slipping the clutch about 3/4's of the way and then dropping it right at the end, it was hooking up pretty well......Launch control is the only way to go!
Old Mar 5, 2006 | 07:41 AM
DragNRacing's Avatar
A better 60' and a little quicker shifting and it would be 11's. It is definitely possible to do 11's with 114MPH. 12.05@114mph is a good time but not quite where it could be with that MPH.
Stinkapuss where you WOT shifting? I would recommend your drop your tire pressure to 22-23psi even with the Advans. It should help your 60' and modulate the clutch if needed to keep the traction.
Old Mar 5, 2006 | 08:32 AM
Stinkapuss's Avatar
Ok, I will try the 22-23 psi next time out. I was sidestepping the clutch when I launched so I will ease into it next time. I was working on my reaction times so I let the clutch go. I holeshotted a new zo6 so it was worth it.
I do a partial lift shift.
Old Mar 5, 2006 | 08:51 AM
topnotchevo's Avatar
Good job bro.You can do it 11s r right there
Old Mar 5, 2006 | 10:46 AM
FASTEVO8's Avatar
Yup, I say next time out you hit 11's for sure!
FL_SilverEvo8
Aug 2, 2011 11:20 AM
AlwaysinBoost
Oct 14, 2006 05:56 PM
EVIL_EVO_VIII
May 19, 2006 01:50 PM
Stinkapuss
Oct 11, 2004 03:32 PM
Rollaway
Dec 24, 2003 04:52 AM
