what more do i have?
my car dynoed 350 hp & 350 ft lbs
ran it last night for the first time got 1 pass 1/4 12.578 mph 110.51 rt .104 60 1.81 this is on 22 psi pump humidity was 100 last night though after i ran it rained as i was turning around to get my slip what do you think i could go ?!!!?? :mitsu: |
I think the humidity certainly wasn't helping and a cooler night may produce better times and traps.
What are your mods?
ams unpper & lower ic pipe
full 3`` exhaust k&n cone filter walboro 255 boost controller hks 280 exhaust cam' turbo trix tune 350hp 350 tq |
You should be in the 11's with all those mods. The temp didnt help but it looks like you need to learn to slip the clutch better and shift faster. I shift slow too so don't feel bad LOL.
Well, whenever you race in the same conditions as when you dyno'd 350/350, you'll be able to trap 114, which is good enough for 11.9-12.1 depending on driving. For only one run, that wasn't a bad et/mph, but it is a little disappointing to see 110mph on a 350whp car. 110mph is around 305-310whp, but that's not to say you wouldn't run a 112-113 if you got 3-4 more tries.
I dynoed with 339hp and 32Xtq at TT dynojet and ran 12.0@113 at etown with 1.68 60'. You dynoed with a little more hp and 20+ more tq. You definitely have more out there, don't give up!
what kind of clutch do you guys think i should go with i was leaning to the act seems like a good clutch for the money
& should i do a flywheel with it also ? |
I didn't like my ACT. I recommend just doing an Exedy Twin HD so you have a great clutch that launches and shifts wonderfully while not having to worry about replacing it again soon.
I currently use the Exedy single disk 4-puck, and it is freakin awesome, too, but it is a bit harsh, so I usually only recommend to people who plain to really use it and don't mind about a little harshness getting the car moving in 1st. |
Yes actually all 4 pucks are pretty harsh. I recommend the exedy twin HD if you plan on making alot of power. Thats actually what I am going with. If not then the tripple disc. Depends on what I can get each one for.
