what more do i have?
Old Jun 30, 2006 | 05:54 AM
dsmjeffro's Avatar
my car dynoed 350 hp & 350 ft lbs
ran it last night for the first time got 1 pass
1/4 12.578
mph 110.51
rt .104
60 1.81
this is on 22 psi pump
humidity was 100 last night though after i ran it rained as i was turning around to get my slip
what do you think i could go ?!!!??
Old Jun 30, 2006 | 07:51 AM
3000ways's Avatar
I think the humidity certainly wasn't helping and a cooler night may produce better times and traps.
Old Jun 30, 2006 | 08:51 AM
Rnm's Avatar
Rnm
What are your mods?
Old Jun 30, 2006 | 11:00 AM
dsmjeffro's Avatar
ams unpper & lower ic pipe
full 3`` exhaust
k&n cone filter
walboro 255
boost controller
hks 280 exhaust cam'
turbo trix tune
350hp 350 tq
Old Jun 30, 2006 | 11:45 AM
05WhiteEVO8's Avatar
You should be in the 11's with all those mods. The temp didnt help but it looks like you need to learn to slip the clutch better and shift faster. I shift slow too so don't feel bad LOL.
Old Jun 30, 2006 | 02:14 PM
Warrtalon's Avatar
Well, whenever you race in the same conditions as when you dyno'd 350/350, you'll be able to trap 114, which is good enough for 11.9-12.1 depending on driving. For only one run, that wasn't a bad et/mph, but it is a little disappointing to see 110mph on a 350whp car. 110mph is around 305-310whp, but that's not to say you wouldn't run a 112-113 if you got 3-4 more tries.
Old Jun 30, 2006 | 02:26 PM
kevo's Avatar
I dynoed with 339hp and 32Xtq at TT dynojet and ran 12.0@113 at etown with 1.68 60'. You dynoed with a little more hp and 20+ more tq. You definitely have more out there, don't give up!
Old Jul 1, 2006 | 06:51 AM
dsmjeffro's Avatar
what kind of clutch do you guys think i should go with i was leaning to the act seems like a good clutch for the money
& should i do a flywheel with it also ?
Old Jul 1, 2006 | 03:52 PM
Warrtalon's Avatar
I didn't like my ACT. I recommend just doing an Exedy Twin HD so you have a great clutch that launches and shifts wonderfully while not having to worry about replacing it again soon.
I currently use the Exedy single disk 4-puck, and it is freakin awesome, too, but it is a bit harsh, so I usually only recommend to people who plain to really use it and don't mind about a little harshness getting the car moving in 1st.
Old Jul 2, 2006 | 12:47 PM
SKILMATIC's Avatar
Yes actually all 4 pucks are pretty harsh. I recommend the exedy twin HD if you plan on making alot of power. Thats actually what I am going with. If not then the tripple disc. Depends on what I can get each one for.
jaysonmyfeet07
Dec 3, 2008 08:35 AM
sti killer 187
Sep 10, 2006 07:56 PM
b0ostedEV08
West Region
Apr 25, 2006 11:31 AM
