-   Drag Racing (https://www.evolutionm.net/forums/drag-racing-16/)
-   -   Buschur Mods put another stock turbo in the 11's...Video Inside (https://www.evolutionm.net/forums/drag-racing/347623-buschur-mods-put-another-stock-turbo-11s-video-inside.html)
BURNALL_4 May 25, 2008 06:31 PM
OK guys, I finally got to the track and overall I'm happy. The car made its fastest pass yet and backed it up, but still not quite what I was looking for. I wanted an 11.7 at 115-116 which the MPH was there but I only got 3 passes in and was making air pressure adjustments eash pass. I guess that i have a starting place the next time I go. If I can cut a mid 1.6 60' the car will pull it the rest of the way.
Mods:
BR Intake
BR Turboback
BR Inline Boost controller 24psi
Cosworth M2 cams and supertech valvetrain
Ecu flash Not fully tuned
Exedy Twin-disc HD
93 Pump Gas
This pass the tires were at 22psi in the front and and 18psi in the rear. It felt like it bogged a little but after reviewing the run I should have made another pass on this pressure setting and launched the car harder.
60'---------1.748
330'-------4.968
1/8 mile--7.677
1/8 mph--90.50
1000'-----10.011
1/4 mile--11.980
1/4 mph--114.45
This run the tires had 38psi in the front, and 36psi in the rear. It did a pretty big burnout and thats the reason for the poopy 60'. This however was the quickest and fastest pass of the day.
60'---------1.801
330'-------5.003
1/8 mile--7.680
1/8 mph--91.90
1000'-----9.987
1/4 mile--11.932
1/4 mph--115.78
Last pass ok, the pressure was at 26psi in the front and 28 in the rear. It spun almost as bad as the second pass.
60'---------1.778
330'-------4.985
1/8 mile--7.667
1/8 mph--91.59
1000'-----9.982
1/4 mile--11.939
1/4 mph--115.05
Make sure you click to view in High quality. HD Goodness!!!
http://www.youtube.com/watch?v=BecmgRwP-FQ
BURNALL_4 May 26, 2008 05:00 PM
So what does everything think???....Am I pissing in the wind going for an 11.7, or no.
CA$H May 26, 2008 05:11 PM
From what Ive seen thats about where you should be. 11.7 might be a record with your mods on pump.
good luck
Tarmacisback69 May 26, 2008 05:17 PM
get sum race gas with a tune, and got a 1.6 definently not outta the question
k2boarder3187 May 26, 2008 06:25 PM
nice man i wanted to go to lebanon this weekend but didnt get a chance to! hopefully i will be there next weekend
BURNALL_4 May 26, 2008 06:39 PM
If its nice, ill see you there!
k2boarder3187 May 26, 2008 07:01 PM
yea looking at the 10day forecast doesnt look good...but that could change from now.
Im hoping and SHOULD be in the 11's
ill let you know later on in the week if im going up!
EVIL_EVO_VIII May 26, 2008 07:05 PM
11.7 is doable on pump.. My car went 11.7@114 on 93 oct on the stock clutch
Pirana May 26, 2008 08:41 PM
whats you launch RPM? and is your transfercase stock?
BURNALL_4 May 26, 2008 10:39 PM
6k launch control, and its a stock RS transfer case.
Pirana May 27, 2008 05:58 AM
Impressive...good runs!
LilRico Jun 17, 2008 08:14 PM
Very nice man... Thanks for sharing your results! {thumbup}
11.7's is able to be done, just got to get a 1.6.... It's hard, but possible...
eponti Jun 17, 2008 08:21 PM
Nice run.CONGRATS
Pirana Jun 17, 2008 09:14 PM
maybe some one can help me out or explain what is happening to my runs. I did a 1.59/60ft the car is not that fast I guess since then it runs a 7.9 on the 1/8 and follows with a 12.2 on the 1/4. But with a 118mph trap?!?
BURNALL_4 Jun 17, 2008 09:33 PM
Thats weird, what was the mph at the 1/8? it seems like the car is making good power, but maybe your shifting might be slow??? not really sure just grabbing at straws.
