16" Rotas & QTP's with the stock brakes!
While on our quest for an 11.0 pass in my DD stock turbo Evo, one of the adjustments that we wanted to make was tires/more traction. These are the same tires from Devin's 8 second Talon, and we decided to throw them on the Evo and see if they fit.........so, what do you think? ;) Sorry the cars not clean:crap:
It's a 16" Rota slipstream with a 26" tall Hossier QTP, all with the stock brakes. Who needs the hard to find rx-7 wheels??!!?? Has anyone put this 16" rim on their Evo with the stock brakes yet? Just curious..... Devin used 20mm Ichiba wheel spacers all the way around. They are not needed in the rear but the skateboard look is {thumbdwn} Kristin http://i280.photobucket.com/albums/k...22/Evo/025.jpg http://i280.photobucket.com/albums/k...22/Evo/023.jpg |
Looks nice. Good to know that they fit.{thumbup}
-Em |
How much does the rim weigh?
It's 12 lbs for a 15", and 13.5 lbs for a 16". So nice and light!{thumbup}
And thanks Emery! Kristin |
How much are they and what colors do we have to chose from.
16x7 et40?
oh only 16x7? no 16x8?
Can we get the exact specs for the rims please? Thanks!!
Originally Posted by evodan2004
(Post 9315371)
http://www.rotawheels.com/wheels.asp?wheelid=40
Originally Posted by StreetThisEvo
(Post 9315548)
Devin |
Looks sick Devin!!{thumbup} I believe 11.0 is in reach!:D
Nice! I was waiting for someone to do this set up. But if it is a 35 offset why would you need spacers? I have the same rim but in a 17 with a 35 offset and it clears with out any probs.
I looked at the site you posted and they do make them in a 16x8 40 offset 5-114.3. So that would mean you need a 5 mm spacer for it to clear right? |
is there a difference in a 7 inch VS 8 inch wide rim when running the same QTP tire? the reason i got the RX-7 rim is because it was 8 inch and light.
The car looks like a mean mofo :) bottom 11s next time out for sure!! P.S. The wingless look is sexy ;)
good info... also in for exact offset specs?
It be great to find one that doesn't need extended studs and or 20mm spacers.
| All times are GMT -7. The time now is 04:30 AM. |
