Kozmic - World's Fastest SST - 9.4@154mph (Half mile coverage inside also)
Finally I have a chance to breathe since the last few events and all the stuff going on around the shop.
We reset our previous SST record (9.7 on stock frame/replacement) at IFO in San Antonio a few weeks ago. Here is a little video of the pass: The following week, we went out to the Wanna Go Fast 1/2 Mile event and attempted a few passes for ****s and giggles. Was a great weekend out there and I plan to attend again when it comes around. Another angle of the video from inside the corvette http://www.evoxforums.com/forums/ima...ies/shades.gif Engine: Kozmic 2.4L Stroker - Brian Crower 98mm Crankshaft, Manley I Beam Rods, Custom Wiseco HD Pistons (10.5:1), ACL Coated Bearings, ARP Mains Cosworth Head Stud Kit Kozmic Ported Cylinder Head - Supertech +1mm Valves (I&E), Brian Crower Valve Springs with Ti Retainers, Kelford 214-C Cams New Updated Timing Chain and new Timing Components Power Making: ETS Vband 6466 Turbo Kit ETS 3.5" Intake with Velocity Stack Kozmic Fender Side Exit Exhaust Kozmic K27 Upper Pipe ETS 3.5" Intercooler OEM X Lower Piping Synapse DV Kozmic K27 Catch Can Kit Kozmic K27 Fuel Rail Kit ID2000cc Injectors Transmission: Kozmic Overhauled Transmission Experimental Dodson Sportsman Pro Clutch Kit- Kozmic Install Spec Dodson Heated Sump Kit Drivetrain/Brakes/Suspension: KSport Coilovers New Blank Rotors with Hawk HP+ F/ HPS R Pads Megan Camber and Toe Arms DSS Driveshaft Kozmic Rear Diff bushings Torque Solutions Front and Side Engine Mount/Inserts Boomba Rear Engine Mount Exterior/Interior: Kozmic Bumper Shutters and IC Air Guide Shutters Seibon Dry Carbon Hood with Aerocatches Seibon Carbon Trunk Kozmic 10 Point NHRA Cage Kozmic Parachute Kit, Tied into Roll Cage |
Awesome!! Congrats on the record!
Originally Posted by Jmills
(Post 11544910)
what does car weigh? looks pretty stripped. how many asses you get before trans needs a rebuild? sounds like clutches are not holding..
That car moves was great to see it in action!
| All times are GMT -7. The time now is 09:45 PM. |
