Kozmic - World's Fastest SST - 9.4@154mph (Half mile coverage inside also)
Old Dec 3, 2015 | 06:02 AM
speedingtwinky's Avatar
Thumbs up Kozmic - World's Fastest SST - 9.4@154mph (Half mile coverage inside also)
Finally I have a chance to breathe since the last few events and all the stuff going on around the shop.
We reset our previous SST record (9.7 on stock frame/replacement) at IFO in San Antonio a few weeks ago. Here is a little video of the pass:
The following week, we went out to the Wanna Go Fast 1/2 Mile event and attempted a few passes for ****s and giggles. Was a great weekend out there and I plan to attend again when it comes around.
Another angle of the video from inside the corvette
Engine:
Kozmic 2.4L Stroker - Brian Crower 98mm Crankshaft, Manley I Beam Rods, Custom Wiseco HD Pistons (10.5:1), ACL Coated Bearings, ARP Mains
Cosworth Head Stud Kit
Kozmic Ported Cylinder Head - Supertech +1mm Valves (I&E), Brian Crower Valve Springs with Ti Retainers, Kelford 214-C Cams
New Updated Timing Chain and new Timing Components
Power Making:
ETS Vband 6466 Turbo Kit
ETS 3.5" Intake with Velocity Stack
Kozmic Fender Side Exit Exhaust
Kozmic K27 Upper Pipe
ETS 3.5" Intercooler
OEM X Lower Piping
Synapse DV
Kozmic K27 Catch Can Kit
Kozmic K27 Fuel Rail Kit
ID2000cc Injectors
Transmission:
Kozmic Overhauled Transmission
Experimental Dodson Sportsman Pro Clutch Kit- Kozmic Install Spec
Dodson Heated Sump Kit
Drivetrain/Brakes/Suspension:
KSport Coilovers
New Blank Rotors with Hawk HP+ F/ HPS R Pads
Megan Camber and Toe Arms
DSS Driveshaft
Kozmic Rear Diff bushings
Torque Solutions Front and Side Engine Mount/Inserts
Boomba Rear Engine Mount
Exterior/Interior:
Kozmic Bumper Shutters and IC Air Guide Shutters
Seibon Dry Carbon Hood with Aerocatches
Seibon Carbon Trunk
Kozmic 10 Point NHRA Cage
Kozmic Parachute Kit, Tied into Roll Cage
Old Dec 3, 2015 | 08:17 AM
Jmills's Avatar
Awesome!! Congrats on the record!
Old Dec 3, 2015 | 04:10 PM
Thanks!
Old Dec 8, 2015 | 11:31 AM
94AWDcoupe's Avatar
what does car weigh? looks pretty stripped. how many asses you get before trans needs a rebuild? sounds like clutches are not holding..
Old May 4, 2016 | 01:55 PM
evo_dean's Avatar
That car moves was great to see it in action!
EliasDiaz
Dec 9, 2013 05:49 PM
kozmic27
Evo X Dyno Results
11
Sep 24, 2013 03:49 PM
KozmicMotorSpts
Nov 5, 2012 12:59 PM
Nesiop
Nov 15, 2011 08:21 AM
