engine diaper
can anybody share which has good fitment for CT9A and if you have any cons using it over a drip pan? Application will only be used on race days and removed, car drives to and back from the track and is a daily driver.
Your engine shouldn't need a diaper. If you've got leaks, fix them. Especially if your car is a part time track toy.
Now with my opinion out of the way, I can't recall ever seeing an engine "diaper" for our cars. Why not use an undertray? |
Many drag racing events require an engine diaper or catch pan under the motor and trans to reduce spillage in the event of a motor failure. They really do help.
OP, I would suggest building an undertray with a "box" to catch fluid, it's pretty simple, I've done a few. |
