Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Need help getting 60' down..
Old Feb 15, 2005 | 11:40 PM
IllicitRalliart's Avatar
First time back to the track in 3 years and I didnt do so bad.. But I need practice.Any Suggestions on how to get my 60' lower than a 2.3? My RT gets better every run so that isnt an issue... Just need Shifting ideas and any other helpfull hints an how to get them darn 60's down... BTW I am FWD.. AS the name indicates I have a Ralliart.ANd please no "shoulda gotten a Evo" remarks.I hear that alot and regret not getting one when I could have(parents needed to borrow my car at the time).
Thanks
Old Feb 16, 2005 | 06:23 AM
blk-majik's Avatar
2.3 is my best so far in the ralliart. infact, its the best anyone has gotten in the registry.
what tire pressure are u running? stock tire?
what RPM are you launching at? slip or feather?
i had good luck at ~24psi, 2400rpm, feathering. that was /w stocks. i might go to the track tonight, so we'll see if i can get into 2.2 =)
Old Feb 16, 2005 | 11:04 AM
i was on 22 psi with stockers. i didnt feather. just dump and pray at about 3k rpm. and spun all the way through 1st. gonna try and go to the track on sunday and work on my feathering
Old Feb 16, 2005 | 11:12 AM
JESSEFREITAS's Avatar
try not to dump the clutch, i would try slipn it a little.
Old Feb 17, 2005 | 10:09 PM
Thanks.. I will try that.That might help a bit.
Old Mar 16, 2005 | 11:22 PM
PeteyTurbo's Avatar
You need to find the balance between spinning and bogging while spinning ever so slightly..Drop the front tire pressue alittle and you could even buy spring spacers at an auto parts store for your rear springs to help weight transfer..2.2 is probably the best youll get
