Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
manual driving tips?
Old Jan 16, 2007 | 10:44 PM
  #31
sean2sean's Avatar
hm... nice tips!
Old Jan 25, 2007 | 03:59 PM
  #32
sonicnofadz's Avatar
Originally Posted by Richard EVO
Practice practice practice. Be sure to blip the throttle on downshifts to match revs.
I have been driving manual gearboxes for 33 years and I would never own an automatic, tiptronic or even DSG or F1 car. Driving a stick/clutch is a much more rewarding and engaging experience. Especially in an EVO. You are lucky to have an EVO as your first manual car. I had a used 1969 VW Beetle for my first stick and it was a POS.
Rev matching is a very important technique to learn if you ever want to become a competitive driver.
Old Mar 3, 2007 | 09:18 PM
  #33
Jon54956's Avatar
My advice is to make sure your seat is set up perfectly for you. I know when I first started driving stick, it was really awkward because my seat was too far back and to get my clutch pedal all the way to the floor I needed my leg fully extended AND my foot needed to be stretched completely (think walking on your tip toes). I later moved my seat forward a bit so when my leg is fully extended, my heel has the clutch pedal all the way to the floor. I can still use my toes to be more precise if I want to be, but I don' need to worry about my foot being overly tired.
I like this method a lot because if anyone every messes with my seat when I get an oil change, I just push the seat lever up and fully extend my leg and, voila!, it's back to normal!
Old Mar 3, 2007 | 09:34 PM
  #34
Jeovannie's Avatar
I dont think is a bad car to learn. My girlfriend is learning to drive stick in my car.
Old Mar 3, 2007 | 09:49 PM
  #35
Jon54956's Avatar
The Evo isn't bad to learn stick... it's not the best, though. On the bright side, once you learn stick on an Evo, you'll probably breeze through driving stick for most any other car you'll ever buy.
How to not nuke your Evo clutch in the first week:
-If you rev past 2,000rpm while the clutch isn't in engaged, DO NOT even think about letting the clutch out unless you like the smell of burning clutch.
-Be SUPER careful changing gears. The last thing you want to do is wreck your syncros or whole transmission because you half-@ssed shifting completely or let out the clutch too early with the gear not fully engaged.
-Be smooth. I recall when learning to drive there was the phrase "turn half as much as you think you should", well, the opposite is true for the clutch pedal -- lots of people let out the clutch waaaaaay too fast or jerky and that shocks the transmission, too. Let the clutch out slowly and smoothly.
-Most of all, have fun with it and don't get discouraged!!! Learning stick in an Evo means you're doing better than like 99.9% of people that learned stick and when you're done, you're driving a cooler car than like 90% of the population!
Old Mar 4, 2007 | 03:16 PM
  #36
Kordyte's Avatar
It's a decent car to drive, as manuals go. As a valet, I've driven pretty much everything, and the Evo is a good setup. Good clutch feel, shifter, etc.
Old Mar 4, 2007 | 07:30 PM
  #37
smarsenal's Avatar
For people learning to drive a stick for the first time on an Evo, don't worry too much about burning out the clutch. Too many members here have burned out their clutches early anyways. A lot of members just take it as part of what's expected with the Evo. I wonder what the average duration of the stock clutch is for EvoM members? (eventhough, I don't believe the stock clutches are as weak an people say!!) I think it's more about how the cars are driven.
Old Mar 7, 2007 | 04:27 PM
  #38
ziggity's Avatar
I started learning stick on the Evo, and that was a big ****up on my part. Put a great deal of wear on the clutch, and ended up getting it repaired.
I ended up garaging it for about two months, and I borrowed a friend's 240sx. The clutch was much more forgiving, and after learning how to slip, hill starts, etc, coming back to the Evo was cake.
Old Mar 10, 2007 | 11:13 AM
  #39
Adrenaline718's Avatar
I found this writeup on nissanclub.com and thought it was a really comprehensive explanation. I drove a manual 20 years ago when I first started driving, and then recently came back to a manual Altima SE-R after many long years of automatics. I'll never go back to automatics if I can help it, and I will be buying an Evo soon to park next to my SE-R in the garage. Anyway, I hope this writeup helps!
(Sorry for the long post, but thought the info was great - props to Pvick of the Nissanclub forums)
Here is a composite of some writeups I did on this site last year which you may find informative. Since you are just learning to drive a manual transmission, I STRONGLY advise you to take the time and learn correctly and avoid developing any bad habits. Frankly, most people do not know how to properly operate a manual transmission. Set yourself apart from them and be one who does.
Happy reading.
PROPER MANUAL TRANSMISSION DRIVING TECHNIQUES
What follows is a collection of writings which I have posted at various times on this website in an effort to help answer some questions regarding the proper manner in which a manual transmission should be operated. While there are certainly many ways to drive a car with a manual transmission, there is really only one correct way. I was most fortunate to have learned these techniques while I was still in my teenage years. In so doing, I was able to avoid developing entrenched habits before they became really bad habits and difficult to correct. It is my hope that this helps you learn what I have learned and perfected over the years. If you do, you will reap the rewards, both financial and in the knowledge that you have mastered a technique that few do in their lifetimes. Have fun!
Under normal driving situations (not racing), when you start out from a standing start, you do so with the lowest possible RPMs, get the clutch out to full engagement as soon as you can while adding throttle. If you do this correctly, the transition will be smooth and seamless, and the wear on your clutch disk, pressure plate, release bearing, and flywheel will be minimized.
If properly designed (sufficient size and clamping pressure, etc.), and properly installed with no defects (correct torque, non-faulty equipment, alignment, etc.), then the next, and most important, factor to the life of the clutch assembly is the operator.
THERE IS ABSOLUTELY NO REASON WHY A CLUTCH CANNOT LAST THE LIFE OF THE ENGINE UNDER NORMAL DRIVING CONDITIONS.
When I speak of engine life here, I am referring to life before a serious teardown or part replacement such as a timing chain (200,000+ miles) or headwork. If you cannot get at least 100,000 miles out of a clutch, you are doing something terribly wrong. Obviously, racing constitutes a whole different approach and, as such, does not come under this.
Don'ts:
Do not use any more engine speed (RPMs) than absolutely necessary to get the car rolling in first gear.
Do not hold the car on a hill with the clutch.
Do not wait for a traffic light to turn green with the transmission in gear and the clutch depressed.
Do not rest your foot on the clutch while driving.
Do not ride the clutch in any gear (obviously you will to a small degree in first to start off).
Do not down shift by just removing your foot from the gas, moving the shifter into a lower gear, then releasing the clutch slowly.
Do's
Start off smoothly and with low engine speed, and shift in such a manner that if you had a passenger on board, they would not even notice the shifts.
Hold the car on hills with the brakes.. that's what brakes are for. NEVER hold a car on a hill with the clutch. The amount of heat generated by doing this is incredible.
While waiting for a light to change or while sitting in heavy traffic, put the transmission in neutral and get your foot completely off of the clutch petal. Leaving it in gear for extended periods heats up and shortens the life of the release bearing. The normal condition of a clutch is fully engaged so it stands to reason that's where it should be most of the time.
Resting your foot on the clutch petal while driving engages the release bearing.. see above.
Avoid riding the clutch as much as is humanly possible. You will extend its life significantly.
If you do not know how to properly downshift, DON’T. Use the brakes (should do this anyway), and avoid downshifting any more than necessary. Improper downshifting is analogous to riding the clutch because that is what you are actually doing. Learn how to properly downshift first and save yourself the frustration of premature clutch failure.
Clutches are wear items, heavily affected by heat caused by friction. In a front wheel drive car, they are costly to replace, so unless you like shelling out a lot of money periodically for the replacement of these components, learn the correct way. Learn it until it becomes second nature like breathing.
I spent some time teaching a lady with whom I worked 10 years ago these techniques when she purchased a new '92 Honda Accord LX. When I last spoke with her, she had well over 140,000 miles on the original clutch with no signs of slippage. So I'm not jerking anyone's chain here. Learn to operate a manual transmission correctly and you will reap the rewards by saving a lot of money. Plus you will be one of the few who know how to do this right.
I don't mean to set myself up here as some kind of guru because I am not. But I have been driving manual transmissioned cars for over 40 years. I have spent the time to perfect the process into an art form because when done correctly, that’s what it is. When I sold my '88 Mustang LX 302CID, it was 6 years old and had 77,000 miles on it. When the buyer drove it, he asked me when I replaced the clutch because to him, it felt very positive. I told him that I had never replaced it and that it was the original unit. I added that it wouldn't make any sense to replace a clutch after only 77,000 miles since that is not very much wear. He had a little bit of a hard time believing this, but he did buy the car. Three months later, he called me up to let me know how much he liked the car and to tell me had had not wrapped it around a tree. He again asked about the clutch and I again told him that it was the original clutch.
I used to own a 1966 Chevelle SS396/360HP. I was the original owner of the car. For a period of about 2 years, I was street racing the car frequently on the weekends. At 83,000 miles when I sold it, it would still break traction in all four gears and the clutch had no slippage. It was tight and strong. Now granted, American cars have traditionally had stronger clutches than Japanese cars. This is changing because the Japanese are putting larger and stronger (torque) engines in their cars.
Downshifting
Ah yes, downshifting. If I had to name just one facet of manual transmission errors-of-operation, this would probably be it.
To understand how to operate a manual transmission, you have to know how the clutch assembly and transmission work, and I am going to take the assumption that most do on this forum. I will only clarify synchronizers. They serve to match the speed of the gears in the transmission as the shifter is moved to a given gear. Now for downshifting.
Let's say you are in fourth gear and you are approaching a stop sign, so you decide to downshift from fourth gear into third. What most people do is just remove their foot from the throttle, depress the clutch while moving the shifter from fourth to third, then start releasing the clutch slowly until they achieve full engagement. If you do this, what you are actually doing is riding the clutch in third gear. After all, the engine has returned to idle (or close to it), you get into third, then just ease the clutch out which pulls the engine from idle up to the RPM's at which it will operate at whatever speed you are traveling in third gear. Here is the correct way to do this in steps that I will break down in a moment.
Raise your foot off of the throttle.
Depress the clutch.
Start the shifter up into third.
As you pass through the neutral gate, let the clutch out (doesn't have to be all the way) while at the same time blipping the throttle to increase engine speed BEYOND that which it will operate in the chosen lower gear.
Depress the clutch again.
Engage the chosen lower gear.
Let the clutch out while adding throttle.
As the engine RPM's decrease they will be met by the engaging clutch and opening throttle.
This should be a simple, smooth, fluid motion and you will know you've done it right if there is no jerking as the clutch comes out in the last step. Now for some details.
As you move into the neutral gate with your foot off of the throttle, the engine RPM's will be returning to idle. This is the point at which you want to blip the throttle a bit while at the same time engaging the clutch some. You want to get the engine turning faster than it will when you are in the lower gear you have chosen. The reason is that you want to spin the gears up to a speed that equals that at which they will be operating when you finally release the clutch in your downshift. If you do this right, there is no clutch slippage because the engine and the gears in the transmission will be spinning at the same or nearly the same RPM's. No slippage means you will get into gear with full engagement of the clutch sooner and with virtually no wear. To best understand this, you really need to know how a clutch assembly and transmission work together to deliver power from the engine to the drive wheels.
This takes a lot of practice, but if you get it down, you will be heads and shoulders above just about anyone else who drives a car with a manual transmission. You will begin to notice the mistakes other are making when they drive. Learn from their mistakes and it will both save you money and make you a far better driver.
So it's in with the clutch, start the shifter into the chosen lower gear, while passing through the neutral gate, blip the throttle and at the same time engage the clutch a bit to spin up the gears, then back in with the clutch as you get into the chosen gear, then finally release the clutch in one smooth operation.
Here's another little tip. Say you are waiting at a light for the green and your transmission is in neutral like it should be with your foot completely off of the clutch petal. When the light turns green, instead of just depressing the clutch and pushing the shifter up into first, pull the shifter partially into a higher gear first, such as second or third. The gears in those selections are not spinning as fast as the gears in first. By starting the shifter into a higher gear before you go to into first gear, you will cause less wear on the synchronizers and they will last far longer because they do not have to stop gears which are spinning at a higher speed. For cars which do not have synchronized reverse, definitely do this and you will not experience the grinding affect when shifting into reverse.
Say you are driving normally, shifting up through the gears to the one in which you wish to be for cruising. As you disengage the clutch and move the shifter to the next higher gear, you might notice a slight resistance just before you finish the shift. What you feel is the synchronizer for that gear forcing the drive gear(s) from the input shaft and the gears selected to "mesh". That is to say, their speeds are forced to equalize so that as they engage, there is no grinding and no damage to the gear teeth. That said, we can move to double clutching.
Double clutching was a technique that came about when earlier manual transmissions did not have synchronizers. If you did not double clutch, you would experience some serious gear grinding when shifting.
If you did not have synchronizers in you transmission, you would have had two choices when shifting gears: (1) put up with some really serious grinding and damage/breakage to gear teeth, or (2) manually match the speed of the gears in each selected shift so that you would eliminate the problems just mentioned in #1.
Suppose you are traveling in second gear, the engine is turning at 2500 RPM, and you are getting ready to shift to third. At the road speed you are going, let's say that once in third, your engine would be turning at 1800 RPM. When you remove your foot from the gas, the engine is going to loose RPMs quickly and by the time you get into third, the engine might only be turning 1200 RPM. Without synchronizers, you would need to raise the engine back up to 1800 RPM in order for the gears to mesh. By blipping the throttle and at the same time letting the clutch out some when you are passing through the neutral gate, you will both increase engine RPM and increase gear speed. As the engine RPMs fall back off, they will reach a point at which you will be able to complete the shift.
Now downshifting is much like this, only in reverse. In other words, you are going from a higher gear to a lower gear so if your engine was turning at 2500 RPM and you wanted to shift to second, You would want to blip the throttle enough to raise engine speed to perhaps around 3200 - 3500 RPM.
When you are upshifting, the RPMs fall off and most people find it pretty easy to adjust to this and to add throttle at the right time so that when the clutch comes back out, they have the proper RPM's for the gear selection/road speed.
However, most people downshift by (1) removing their foot from the throttle, (2) moving the shifter into the next lower (or chosen) gear, then (3) slowly releasing the clutch while adding little or no throttle. This is NOT the proper manner in which to downshift. What you are doing in effect, is riding the clutch in reverse. In others, you probably wouldn't dare attempt to start your car off in third gear because you would have to add a lot of throttle and really slip the clutch to get the car moving. When you downshift like the example I just gave, you are doing something similar to starting off in a higher gear, though it does take more energy to get a car moving from a dead start. Now if you double clutch during the downshift, you are spinning up the gears and the transition to the next gear will be quite smooth.
Junkyard asked a question about the concept of “passing through the neutral gate”. You don’t stop or stay in neutral. You are just passing through, so to speak. In your second question, you said I had mentioned to put the car in neutral when downshifting. Not exactly. Try this with the engine off.
Put the car in fourth. Depress the clutch and shift to third and let the clutch out. Now do the same thing, only this time as you pass through the neutral gate, let the clutch out some or a good deal and blip the throttle, then clutch back in, get into third, clutch comes out for the final time. That is the movement you want.
Incidentally, blipping the throttle is just a little stab at the petal, enough to raise RPMs to the desired level. You do not want to be on the throttle long because you will be in the process of shifting. Yes, this does take a lot of practice and may not come easily for many, but it is the best way, in fact the only proper way, to downshift because it very significantly reduces clutch and synchronizer wear (especially clutch), and once you get the hang of it, you will be able to do it quite fast.
The bottom line to all of this folks is to match engine speed to wheel speed in a given gear, and to do it in such a manner as to eliminate undue trauma to your drive train. I do this all of the time and have been downshifting like this since my very early 20's. I actually learned it from a magazine article (as I can best recall). If you know how a manual transmission and clutch assembly operate, all of the components and how they perform together, you will understand the beauty of the process.
Oh the grinding noise Junkyard hears when he starts letting up the clutch too quickly is most likely due to not having fully engaged the gear teeth and they separate (pop out of gear). That or he actually begins engaging the gear teeth before the clutch is fully depress so there is still some flywheel/disk/pressure plate contact.
One of the things I noticed right off the bat on my SE was that the clutch began to engage much too close to the floor for me (a contributor to the problem Junkyard has had). It was starting to engage about 1 inch from the floor, so I adjusted it out to 2 inches and it is fine. If you do this, just make sure you have the required toeplay, otherwise you will prematurely wear out your release bearing.
The purpose of letting the clutch out some as you pass through the neutral gate is to spin the gears up in preparation for the speed at which they must be at for the lower gear selection. This will allow you to get into that gear very easily. When you depress the clutch, you disengage the crankshaft from the transmission. The gears in the transmission will begin to slow down. By letting out the clutch some (or completely) in the neutral gate, you once again, MOMENTARILY, engage the full drive train and get the gears spinning. Only this time since you have blipped the throttle, they'll be spinning faster. As they slow down from the higher speed, your clutch will be coming out for the final time with the transmission in gear and the mesh will be smooth.
Try it both ways. Do it first the way you do it and notice that you have to add a little bit of force to get the shifter into gear. That's because the synchronizers are doing their job of gear speed meshing. Now try it the way I outlined and if you do it right, you will have virtually no resistance as you slip the shifter into your chosen gear.
Instead of going right into first as the light starts to go green, try starting the shifter into second gear.. don't have to go all the way into gear, though it won't hurt. This slows the gears down just as though you had gone on into first, but it's much easier on the synchronizers. And you won't get the "crunch" you mentioned when you have to move quickly.
To prevent rollback; practice, practice, practice, practice.
One way to do this is to find a nice little hill someplace where you won't be a bother to anyone. Take along some masking tape and mark off two sections with the tape a foot apart. Your goal is to keep the car from coasting back more than 1 foot.. of course you do not use the clutch to hold the car.. use the brakes. As you learn to do this, find another hill a little steeper. And so on, and so on.
__________________
PVick
2004 Acura TL
Anthracite/Ebony
6sp Manual trans
Navigation
Drop dead Gorgeous
Old Mar 10, 2007 | 12:19 PM
  #40
kikazzdrummer88's Avatar
^^awesome writte up man
Old Mar 12, 2007 | 10:15 PM
  #41
Kayaalp's Avatar
Originally Posted by jjm4life
im always afraid im going to hurt the clutch and need a new one way sooner than i should. thanks
One thing to keep in mind is that a gear change should not look like one single motion. In other words, you don't just grab the lever and slam it into the next gear. Each gear change should basically be two motions: pull the lever out of one gear, pause for a split second in the neutral part of the gate, then push the lever into the next gear. It should feel like "click-click" not "wham."
This is something I always have to work on with my students on the track. Everyone seems to think you need to wail on the brakes, throttle, and shifter. Unless you're dragracing and 1/1000th of a second counts, there's no reason to beat up your gearbox (not to mention risk toasting your valvetrain with a mis-shift) by slamming the lever from gear to gear. You have to be smooth with your inputs.
Also, you should learn the proper way to move your hand on the lever. Go to the UUC Motorwerks website, click on the "Tech Tips" button on the bottom of the page, then click the "Shifting Techniques" link on the left. Learning how to manipulate the lever properly can save you an engine.
Emre
Old Mar 12, 2007 | 10:20 PM
  #42
lilevo1's Avatar
yup just practice... it takes time
and dont but in a rush to shift...
Old Aug 14, 2007 | 05:17 PM
  #43
kyoo's Avatar
I was going through this and I was just wondering if anyone who has driven a manual car before the Evo notice that the RPM's drop a lot slower with the Evo after depressing the clutch? I used to have an impreza before my evo and then RPM's would drop like a rock and I was able to shift relatively quickly. But when I switched to the Evo everything got a lot slower.. I had to wait a little for the RPMs to drop and then let out the clutch much much slower than I have in my impreza. Am I doing something wrong with the Evo here?
Old Aug 14, 2007 | 05:25 PM
  #44
kyoo's Avatar
anyone?
Old Aug 15, 2007 | 05:06 PM
  #45
jjm4life's Avatar
wow i started this thread two years ago. funny to think how my driving has improved. im sure you guys are like me, nothing puts a smile on your face like a perfectly executed downshift. i forgot all about ths thread. hope its helped some new manual drivers in the past two years
