to lift or not to lift clutch?
to lift or not to lift throttle?
in drag racing.... lift the throttle or not when shifting gears! Which one gives you better ET? (im not asking here for me) Just want to know what drivers best ET w/ or w/o clutch lifting)
Yeah, you'll go quicker w/ the throttle matted the whole way, but you'd better be quick and precise w/ that shifter & clutch pedal--or else...
there's two ways...either lift the clutch or lift the throttle...
both are ways to go faster but you can't do both. i'd say keep the throttle down and lift the clutch.
On a small stock like turbo it won't make much difference unless you granny shift. Those of us that ninja shift with a throttle and clutch lift will probably run the same times with NLTS.
Why risk breaking **** to MAYBE be .05 sec faster?
Practice on a old car. I can no lift (throtle) through every gear. Just have to be fast and on time. But it does hurt drivetrain more. When shep did my tranny he had to put a new 2 gear in cause of my abuse. That was at 20k, I wasnt having issues just wanted an upgrade. And with his tranny (shep) it shifted so smooth and easy at redline, I dont think you could miss a gear.
