Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Does this waste gas?
Old Dec 14, 2007 | 09:29 PM
Oki Panoki's Avatar
Say im driving down a hill or just on the road and i leave the gear engaged (its at lets say 2500rpm) and let the trany slow the car down. If i dont put my foot on the gas at all, does it still burn as much gas as if i would keep my foot on the accelerator at that same rpm.
I dont think it would, cuz im not feeding the engine as much air so its basically the same as idle, correct?
Old Dec 15, 2007 | 11:57 AM
Oki Panoki's Avatar
does this make sense or do you need me to clarify
Old Dec 15, 2007 | 12:01 PM
EvoDan2004's Avatar
lol
Old Dec 15, 2007 | 12:04 PM
wizzo 8's Avatar
yes you are saving gas by engine braking
Old Dec 15, 2007 | 12:19 PM
dxbtune's Avatar
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
but you could save even more by using the handbrake and shutting off the engine...
Old Dec 15, 2007 | 05:33 PM
JJsevol's Avatar
^^haha or leave it in neutral...although it is illegal in some states.
Old Dec 15, 2007 | 05:40 PM
K1lla Haz3's Avatar
i usually put it in neutral.....
Old Dec 15, 2007 | 05:49 PM
UT_Evo's Avatar
I usually don't worry about saving gas when I'm in a performance car...
Old Dec 16, 2007 | 07:57 PM
Oki Panoki's Avatar
ic, but i dont consider my current lancer a performance car when i buy my evo in 3 months, then...
Old Dec 19, 2007 | 12:24 AM
BoostLover99's Avatar
I understand that this accurate; you would be burning only the idle amount of fuel when the throttle is at 0%.
I think that's accurate, anyway.
Old Dec 19, 2007 | 06:08 AM
Profoxcg's Avatar
Is the reason my EGT's go lower as the engine slows down the car because the car is leaning out based on the load of the engine?
Old Dec 19, 2007 | 11:31 AM
kilgoja's Avatar
using the engine to slow down also saves your brake pads from wearing out as fast
Old Dec 19, 2007 | 11:32 AM
Profoxcg's Avatar
doesnt that wear out the clutch? - I guess not because the clutch is engaged right?
Old Dec 19, 2007 | 12:18 PM
toovira's Avatar
No, unless your clutch is slipping...
Old Dec 19, 2007 | 12:24 PM
Mr. Stock's Avatar
If you let the car coast IN GEAR, with your foot off the accelerator, the ECU goes into fuel cut mode and no gas is being injected into the engine. You can actually feel the fuel come back on if you let it get down to around idle, depending on the elecrtical load.
