-   Driving Techniques (https://www.evolutionm.net/forums/driving-techniques-65/)
-   -   what's the best and quickest way to launch an evo from rest? (https://www.evolutionm.net/forums/driving-techniques/247510-whats-best-quickest-way-launch-evo-rest.html)
w00tev0 Jan 25, 2007 11:56 AM
i keep hearing different opinions on how to best launch my nearly stock evo from rest. do you drop the clutch at 4000, 4500? is that too hard on the clutch / transmission? how much can the stock clutch take?
sonicnofadz Jan 25, 2007 12:00 PM
flash your ecu to enable a two step launch limiter. Set it around 5000-6000 rpms. Floor the gas pedal, bounce of rev limiter, dump clutch. Have fun breaking things! :)
Chemwarrior Jan 25, 2007 12:02 PM
That's messed up. Why do you want to set the guy up for failure like that?
Warrtalon Jan 25, 2007 12:05 PM
Probably because he didn't bother to search or get any real info before posting as a newbie without going to the drag racing forum or newbie forum, which is against several rules.
Srt-4 Turbo 7 Jan 25, 2007 12:08 PM
I am a newb just like yourself "wootevo" but searching is your friend. Get a tune and set your 2-step to 5,500-5,800 rpms whatever you choose. Floor is and bounce off of your 2 step. Give the clutch a QUICK slip and then hold on. Do NOT just dump the clutch, unless you have a s**t load of money sitting on the side to replace your transfer case and clutch all the time. Go to the bottom of the forums and click on the "Drag Racing" section. Do a search there and you will find all of your answers.
KOEvo Jan 25, 2007 12:09 PM
Or because it isn't setting him up for failure at all, because that IS the right way to launch an Evo. If you're going to "actually" launch an AWD car, things will break...
Chemwarrior Jan 25, 2007 12:16 PM
That was kind of my point KOEvo. Why would a noob (yes I realize I am one as well) want to launch his car without properly researching the correct way of doing it. I wasn't questioning your methodology. {thumbup}
ThunderOZ Jan 25, 2007 12:18 PM
Have you checked the Driving Techniques section. Or the Drag section? There's a lot of helpful info there...
w00tev0 Jan 25, 2007 12:19 PM
got it. noob mistake, my bad. i'll check out those other sections and do this so called "searching" next time.
bluebyu36 Jan 25, 2007 12:22 PM
arrest that man !!!!!he did not search!!!!!
ThunderOZ Jan 25, 2007 12:23 PM
He hasn't been here long... He'll learn.
Smike Jan 25, 2007 12:24 PM
Do not drop the clutch...and please search...
Advance search quick slip and Warrtalon, Clay has a nice write up and video on how to launch w/o the 2step
When/if you get flashed for the 2step, here is my 2step tech (as a bit more in it but the 2step is in it):
https://www.evolutionm.net/forums/sh...75&postcount=4
fastgt350 Jan 25, 2007 12:57 PM
nice{thumbup}
sonicnofadz Jan 25, 2007 01:06 PM
In my opinion this is the quickest way to launch a near-stock Evo. It just happens to be the most damaging for your drivetrain =)
moreryce Jan 27, 2007 03:37 AM
if ur gonna drag u should get a AWD launch club card from ACT clutches.. lol
