Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
how to launch me car
Old Dec 26, 2006 | 08:42 AM
david's IX MR's Avatar
i know it sounds funny but i cant really launch my car!!! all of my friends have tried and and they cant do it either... can some1 please tell be because it is obviousley not the same at a rear wheel drive car...thax
Old Dec 26, 2006 | 08:46 AM
bluebyu36's Avatar
all your friends try to launch your car (i hope not)if u cant do it dont even try your going to break something!
Old Dec 26, 2006 | 08:47 AM
bvdawg13's Avatar
if you dont try, how r u ever gonna learn?....hold it at the 2 step then quickly release the clutch, but dont just drop it
Old Dec 26, 2006 | 08:49 AM
Smike's Avatar
Here is my tech. w/2step. ((This should be done only at the track)) ((And be careful - or your clutch is not going to like you much longer))
At the lights use shallow stage. This means as soon as you engage the 1st amber, slowly roll into the 2nd amber. As soon as that is lit, stop. ((This gives you a few extra inches to get it moving before the timers come on.))
Clutch in, gas to the floor, bouncing off 2step. Walk the clutch out a little bit just to the point that you feel all the slack coming out of it. Almost to the point of moving the car - hold it right there.
Amber, amber, green --- walk the clutch back fast but not dumping. Hold on for dear life and you are off and running (of course go before you see green - its all in the timing).
When done right it feels like all 4 are spinning and you are going like a bat-outta-hell.
On stock turbo and cams shift at 6800 to 7000 in all gears. You should be in 4th through the traps (GSR/RS for gearing)
Old Dec 26, 2006 | 08:50 AM
EVOLVEU's Avatar
if you dont have 2 step(which I believe you do, correct me if Im wrong someone), rev to 5500rpm and slip your clutch. If you are unsure of what that means, Ill explain. Rev to 5500rpm, slowly release the clutch until you start moving, the more you move, the faster you can let the clutch out. With practice, itll get much easier. My advice, get 2 step launch control and use it when launching. What ever you do: DO NOT DUMP THE CLUTCH!!!
Old Dec 26, 2006 | 08:51 AM
whitersevo's Avatar
hmm your going to be asking soon, why is my car not moving when I give it gas, the tach just revs out.
Old Dec 26, 2006 | 08:55 AM
-=SPECTRE=-'s Avatar
Are you a pirate?
Srsly, clutch in, in first gear, floor it, quickly and smoothly release clutch (don't sidestep it), hold on.
Pure Playaer's Avatar
wait, is holding the gas pedal to teh floor a good idea while just slipping the clutch to engaging point?
Old Dec 26, 2006 | 08:56 AM
Originally Posted by -=SPECTRE=-
Are you a pirate?
lmao i was waiting for someone to say it!
It's a good idea if you want to go fast. Not a good idea if you want your clutch to last a long time. Hence why launching the car is hard on the clutch.
Jakeg97's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=233376
https://www.evolutionm.net/forums/sh...d.php?t=230092
https://www.evolutionm.net/forums/sh...d.php?t=213138
https://www.evolutionm.net/forums/sh...d.php?t=203109
https://www.evolutionm.net/forums/sh...d.php?t=213943
https://www.evolutionm.net/forums/sh...d.php?t=188611
Old Dec 26, 2006 | 09:00 AM
Jakeg97's Avatar
cant rev to 5500rpm without
https://www.evolutionm.net/forums/sh...d.php?t=165759
Old Dec 26, 2006 | 09:04 AM
CRX2EVO's Avatar
that's what I came in here to ask, dammit!
Old Dec 26, 2006 | 09:05 AM
EVOLVEU's Avatar
Originally Posted by Jakeg97
ahh, ok. I wasnt sure if it was the 2005 8s, and newer or just the 2005 8s. TY for the info.
Old Dec 26, 2006 | 09:13 AM
yarr, don't be dumpin yar clutch, matey. or you'll be sendin' it straight to davy jones' locker.. savvy?
