DynoFlash [Visit Site]
Dyno chart: BR440 + Dynoflash
Old Nov 2, 2004 | 06:27 PM
propellerhead's Avatar
Well, this past Saturday I had my car dyno'd. This was my first trip to the dyno. I never did baseline the car stock, Overall the results weren't too bad, although they were a little on the low side.
Results: 346whp/312ftlbs
After doing the dyno pulls I was a little dissapointed. After some beeotching I decided to do a leak test and discovered a total of 4 leaks! Also, after fixing the leak I found in my damaged intercooler core I also found out that my 1G BPV leaks at anything past 20psi. Surely there's more power to be had once I fix the boost leaks.
Old Nov 2, 2004 | 06:38 PM
b18flip's Avatar
man, get the leaks fixed....i wanna see the new #'s BTW, how much do BR440+dynoflash'd setups usually put out?
Old Nov 2, 2004 | 07:14 PM
2SloEvo's Avatar
propellerhead, definetly post up your new numbers when all the leaks are fixed!
b18flip, Al has some dynocharts in this section on a brstage4 w/ a 440turbo, putting out around 360ishwhp on 93 and 400whp with a 93/100 oct mix.
BR440 = bada$$ when tuned!
Old Nov 2, 2004 | 07:18 PM
DynoFlash's Avatar
I like the curve - but it seems he was runnig the boost a bit low - this turbo likes 22 - 23 psi - and with the boost leak, its a small turbo so that hurts the power
Old Nov 2, 2004 | 07:29 PM
No doubt I've got some stuff to sort out. Even when cranking the boost up a bit I wasn't seeing any additional power. I think all the little leaks were causing some issues in terms of efficiency.
BTW, I like the curve too. Nice and fairly flat. Hopefully fixing ghe leaks and tweaking the tune will help broaden that curve even a little further.
Old Nov 2, 2004 | 07:38 PM
VTECH8TR's Avatar
Get those boost leaks fixed and you will be Happy .
Old Nov 2, 2004 | 07:49 PM
DynoFlash's Avatar
I have been driving a BR440 equiped Evo with Buschur Stage 4 for a week now
I tell you its a real joy to drive - a real well balanced machine
Old Nov 2, 2004 | 08:12 PM
Check out the timing log from that run. Looks like the ECU is pulling some timing.
Old Nov 2, 2004 | 08:53 PM
DynoFlash's Avatar
Is that timing log from same dyno run or street run ?
Old Nov 2, 2004 | 09:16 PM
That's from the dyno run. You can see the dip inthe power on the dyno sheet where the timing tanks and dips down to 6 deg.
If we do the dyno tune at Pruven after turkey day I'll show you the logger. With a field harness it would make a great plug & play street tuning tool. I've got to get my WBO2 piped into it and have it log that too.
In addition to the friggin boost leaks I'm wondering if I have some bum fuel too. I usually run Shell 93. I effed up and filled up at Amoco/BP. I don't run it too often but it seems like crap gas.
Old Nov 2, 2004 | 09:47 PM
DynoFlash's Avatar
I see that dip. Thats why I want to know the a/f ratio. With 93 octane it should hold 8 degrees in that area. Did they log a.f?
