DynoFlash [Visit Site]
How do you get 2 ecus to work in 1 evo?
Old Dec 23, 2004 | 08:45 PM
turboDan's Avatar
How or should I say has anyone got 2 different ecu's to work in 1 evo on the same set of keys or are 2 different sets of key's required for the different ecu's.I programmed a set of keys to 1 ecu and engine starts,swap out ecu's and programmed same 2 keys to other ecu and engine starts,but when I plug in 1st ecu,just cranks and cranks,like keys were never programmed.What gives.Using hand held Mitsu scan tool to do this.How are people doing the 2 different ecu/flash trick.Al,anyone???I realize that the imobilizer ecu is seperate from ecm,but it must recocognize a different ecu and not send the signal to enable ecu to start vehicle.
Any help would be great.
Old Dec 23, 2004 | 08:53 PM
scott88vr6's Avatar
I would like to know as well! Let me know how this all turns out.
Old Jan 11, 2005 | 08:33 PM
EVOlutionary's Avatar
I would like to know if this is possible also. I would like one custom tune for pump gas and 20psi, and one custom tune for c16 and 25-26 psi. One for daily driver, one for racing. How do we go about this, and getting both to be interchangable to work with the same keys?
Thanks!
EVOlutionary
Old Jan 11, 2005 | 10:30 PM
tlclee's Avatar
Y all the trouble, just get a piggy back.
Old Jan 12, 2005 | 12:04 AM
rebelzx's Avatar
You can, but the second ecu has to be recoded by the dealer for the immobilizer. Otherwise your keys won't start the car with the spare ecu in.
Old Jan 12, 2005 | 02:54 AM
turboDan's Avatar
Go ahead and try that,it doesn't work.The second ecu will start the car and then the original ecu will not.Been there,doen that.This vehicle has its own imobilizer ecu that knows that the ecu that is programmed to it and only 1.The only way to get it to work is to purchase a second imobilizer ecu and have your keys programmed to your 2nd ecu/imobilizer ecu combo
Old Jan 12, 2005 | 07:11 AM
Curt@MrLed's Avatar
Former Vendor
why not a standalone?
Old Jan 12, 2005 | 07:16 AM
Evo Buddha's Avatar
Thanks!
EVOlutionary
Utec or any standalone can switch maps for u.
Old Jan 12, 2005 | 07:24 AM
4ringturncoat's Avatar
Buy an RS...HA HA
Old Jan 12, 2005 | 07:46 AM
turboDan's Avatar
Oh,I do have AEM,just trying to help out a friend that is attempting this as it was all the Hype over the summer,you know 2 ecus flashed,1 for race gas and 1 for daily driving.As far as going full stand alone alot of people like the cost effectiveness of the 2 different ecu's flashed. Extra ecu=$200,Custom flashed/dynotuned ecu=$350
Countless people that you beat=Priceless.Some thing you just cant buy,for everything thing else there is DYNOFLASH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 12, 2005 | 09:40 AM
DynoFlash's Avatar
BTW - it should be noted that for Dyno Flash custom tuned owners the 2nd race gas map in the 2nd ecu is free of charge
Old Jan 12, 2005 | 09:51 AM
cruizinmax's Avatar
Well??
So does anybody know if it is possible? Maybe there is a way to disable the immobilizer ecu. I know people have been succesfully disabling honda immobilizers, I just didn't know if this was possible with mitsu ones.
Old Jan 12, 2005 | 10:36 AM
DynoFlash's Avatar
You have to take it to a dealer and have then load in the imobilizer and key codes. What I am not sure of is if you need two imobilizers - one for each ecu or if you can get away with one imobilizer for both ecus
if your buying a spare one from a wrecked car I would suggest picking up the imobilizer also so you have two of each
Old Jan 12, 2005 | 10:54 AM
cokofellah's Avatar
Thanks!
EVOlutionary
get the XEDE...you can switch maps using that piggy-back
Old Jan 12, 2005 | 12:18 PM
DynoFlash's Avatar
And you will still have a "piggy back" with all its disadavtanges and limitations - WHICH I do not care to get into another "debate" about here. Those who are interested in "piggy backs" can take thier discussion to other areas of these forums
A reflash of the factory ecu is vastly superior to any piggy back system - IMHO
