DynoFlash [Visit Site]
Big Al, Dave Buschur, and some alcohol!
Old Jan 18, 2005 | 11:12 AM
cruizinmax's Avatar
How much boost do you think you could run on a stock motor with conservative timing? 28psi? The reason I wonder is could you say run 28 psi with alcohol and when it runs out turn it down to like 20-21?
Old Jan 18, 2005 | 08:38 PM
EvoTio's Avatar
Originally Posted by DynoFlash
Sure - I will be in La this comming weekend the 21st - 23rd so i am happy to tune you for the alcohol set up
Thanks Al. Unfortunately I am not able to finish up my install by this weekend. The damn rain in LA messed up my last three weekends to work on the car. I'll make an appointment with you next time you come out to L.A. I'm glad your custom tune for 4ringturncoat turned out well. I'm looking forward to see what you could do my set up using our 91 octane.
4ringturncoat, what type of alcohol does Dave use for his injection mixture? I have about 10 gallons of a 50/50 mix of methonal and distilled water. I hope that will work well.
Old Jan 19, 2005 | 03:22 AM
4ringturncoat's Avatar
The BR system uses 100% alcohol. I have been using denatured alcohol which is about 90% ethanol and 10% methanol. I have driven the car pretty hard since last Friday and gone through about 2 quarts so far.
Old Jan 19, 2005 | 07:42 AM
DynoFlash's Avatar
I ordered my kit today !
Old Jan 19, 2005 | 07:51 AM
badlooser's Avatar
Originally Posted by kplunkett
i trap a 122.4 mph with stock motor (cams)
killer mph for a stock motor .......!!!!!!!!!
Old Jan 24, 2005 | 01:34 PM
Al,
I tweaked the boost like Dave said and it pegs 26/27 lbs in first and second almost instantly. The slight leveling of boost when the alky hit is completly gone...this thing is just stupid in first and second now. I would like to see what it does on a dyno. Think I will need the BR580 for tens but this thing must be good for a sub 11.50 pass right now. Your tune as amazing.
Old Jan 24, 2005 | 01:59 PM
midwestmonster's Avatar
What can you realistically run safely on pump gas w/o alchohol? 93 octane.
Old Jan 24, 2005 | 02:04 PM
NYREDEVO's Avatar
4ring.....congrats that sounds great.
What were your wHP before and after? I didnt see that posted?
1 other question,...You said your trying to keep it stealth (I like, LoL) is the alcohol kit stealth enough to get by a dealer? I know you said it uses the intercooler sprayer tank
Old Jan 24, 2005 | 02:11 PM
Darwinator's Avatar
so....am i going to get a ride in this thing?
Old Jan 24, 2005 | 03:48 PM
93h22cvc's Avatar
possibly 700 whp.
Old Jan 24, 2005 | 06:44 PM
kmxxbadboy's Avatar
[QUOTE=4ringturncoat]The BR system uses 100% alcohol.QUOTE]
So keeping a bottle of Jack Daniels around in the car will do the trick.
Old Jan 25, 2005 | 03:01 AM
What she does on the dyno is not that big of a concern, to me the REAL hp proof is in 1/4 mph, not so much et but what she can mph. I was going through the traps at 114 so if you figure out car weight, et, mph and know your a pretty driver you can tell pretty close to what hp your making. Mine was around 430 to 440 at the most at the crank last year.
I can't run the car right now so I am curious to see what she would dyno. The car is soooo much faster now then when she was running 11.90's. I am bettting it is over 440hp (pulling number from a**) on Als dyno. I will always understate performance until I can back it with a few passes. All I know is I have a 9.99 and faster NHRA liscense and pur it to use every now and then, even after going 9.60's in a drag car this thing still feels very very fast.
I doubt the kit will get by the dealer as there is a large stainless hose going into the top ic pipe right by the throttle body.
Old Jan 25, 2005 | 07:10 AM
NYREDEVO's Avatar
Sounds good man..just be clear....you said 440 to the crank which is prob 390 whp and u think ull be around 440 whp with the new set of mods?
Good stuff man!
Old Jan 25, 2005 | 07:12 AM
NYREDEVO's Avatar
I think ull break the 11.5 -11.6 barrier...good luck!
Old Jan 26, 2005 | 06:57 AM
kvcycle's Avatar
Al or Dave, I am really interested in this kit and want to order it. Can you please PM me ordering info or post it. This is easily the best mod to come out for the EVO in a while.
