DynoFlash [Visit Site]
Al-I would think you have a map for these specific mods???
Old Feb 15, 2005 | 01:49 PM
DEVO8250's Avatar
Talking Al-I would think you have a map for these specific mods???
Hey man- I have an 03 Evo VIII and this past Oct-Nov. I got the base flash from you. Very happy.
Well, as we speak, I am have the following installed and would need a new flash for the new mods.
  • Hallman Pro MBC
  • Burshur Racing Turboback with High-Flow Cat and Magnaflow muffler
  • K & N Drop in filter (still with factory airbox)
Hopefully you will have a map for these specific mods.
What boost lovel would you guys recommend as, per my research tells me 20psi should be fine on 93 octane.
Should I see about 290HP 300torque?
thanks
p.s.- I am Fed-xing the ECU to you so you'll have it Thurs. AM. Will I have it by Friday?
Old Feb 15, 2005 | 02:30 PM
SterlingEvo's Avatar
Al has that map for sure... I saw roughly that power with those mods. Also, 20psi is good on 93. That's basically my set up that I ran upper 12's with, although I've seen as low as 12.3 with Buschur stage 1 + "custom" dynoflash...
Old Feb 15, 2005 | 06:04 PM
DynoFlash's Avatar
Thanks Sterling !
Old Feb 15, 2005 | 08:51 PM
schumi's Avatar
ok got your mail in reflash for just a panel filter and 92 now I have the tbe from Buschur 3in installed . I have not installed the mbc you sent yet or the wp 255 pump. can I get more horse power from a new flash with the pump and the tbe with the mbc if yes I will send it in now rather than wait till you get to Chicago again. I will just have to wait on the alcohol injection kit .Thanks for answering my dumb questions twice maby I will just get better at asking them. Oh and once I find a tuner I like I stick with that person as long as I own the car. so you are saying that I will make more hp with a re-flash right. you dont have to answer the pm.
Old Feb 16, 2005 | 04:00 AM
DEVO8250's Avatar
Question get her re-flashed
you're at the same spot that I am -
got the flash for just a filter, thinking "i'm not going to do any more" and sure enough, on goes the 3 inch turboback, and now the MBC, fuel pump.
you'll notice that with the new exhaust installed, with the initial flash, you will be running really rich since you have a whole not more flow than the ecu is expecting. I have all sorts of black discharge and the tip of the exhaust from being way too rich.
once you have the new pump do dump even more fuel in there, and the mbc to pump your boost level, it's definitely going to take a refined tune with all of these additions.
Al- you'll have my ecu tomorrow 2/17 - will you be around for a same day turnaround like last time? I would love to have the new flash for friday night so i can play this weekend! thanks
