DynoFlash [Visit Site]
Installed Injen intake, have a Question!!
Old Feb 26, 2005 | 11:33 AM
wprettyboy's Avatar
I installed injen intake w/ upper and lower intercooler pipes. i have the dynoflash mail in, but its not for the intake and pipes. my question is will i mess anything up running the same boost levels, until i get retuned?
Old Feb 26, 2005 | 12:35 PM
wprettyboy's Avatar
bump for help
Old Feb 26, 2005 | 12:37 PM
djmikeymike's Avatar
where did you get the injen lower intercooler pipes.....i have the injen kit but i don't have the lower pipes......i thought the only way you can get the injen lower pipes is if you get there intercooler.
Old Feb 26, 2005 | 12:47 PM
wprettyboy's Avatar
its not the injen lowers. i was just saying what all i installed. I have the RVM lower pipe, b*tch to put on but i can tell its on there
Old Feb 26, 2005 | 01:08 PM
so the lower pipe made a difference
Old Feb 26, 2005 | 01:31 PM
wprettyboy's Avatar
i can feel a difference in the butt dyno.. I guess no one wants to help me out on this question!!!!!
Old Feb 26, 2005 | 01:37 PM
DizzyTT's Avatar
You should really get a new flash, the intake can cause lean conditions.
Old Feb 26, 2005 | 03:01 PM
UT_Evo's Avatar
Yeah, and the intake won't be gaining you as much power as it can with a tune...
Old Feb 26, 2005 | 03:50 PM
MYEVO8U's Avatar
if anything messes with the A/F on your car, it's changing the intake. You should get a reflash.
Old Feb 26, 2005 | 04:41 PM
wprettyboy's Avatar
i'm getting a reflash after i get my cams, 10.5hotside and turbo manifold in (waitin on manifold to get ceramic coated). i just want to know what boost to run for now that will not hurt anything
Old Feb 26, 2005 | 07:30 PM
mikesevo8's Avatar
Do yourself a favor and turn your boost down as low as it will go until you get retuned.
Some intakes cause very lean conditions in the midrange rpms.
Better safe than sorry, yada, yada
Old Feb 26, 2005 | 07:31 PM
sonics36's Avatar
Your Fine Turn Up The Boost
Old Feb 26, 2005 | 07:39 PM
sonics36's Avatar
Just Kiding.
Old Feb 27, 2005 | 07:38 AM
AcA's Avatar
AcA
So I guess its better to get a flash with intake and then install the intake after the reflash? I have a intake at home to be installed.
