DynoFlash [Visit Site]
Installation of Mods Process
Old Feb 28, 2005 | 08:07 AM
botemarc's Avatar
Will have the following mods and asking anyone for recommendations of the process I should go about on installing them in terms of what I should install first...
Buschur 3" TBE with Highflow Cat and Magnaflow
Walbro 255 fuel pump running on Pump Gas 93 Octane
Hallman Pro MBC set @ 21psi
K&N Drop in filter
MR BOV
Dynoflash from Mr. Al Freidman
Should I install them one at a time and then send the ECU to AL to be flashed?
Should I park it, install everything, send the ECU out and get Flashed
Would it be safe/ok to run without the flash, but have everything installed?
And what is the best psi that I should set my boost in , 21, 22, or 23 PSI?
I will be using this as a daily driver(100miles a day drive to work/home) and occasional drag/autox in the weekends.
Thanks for any comments!
Old Feb 28, 2005 | 08:13 AM
scott88vr6's Avatar
Install everything and have the ECU retuned by Al..get it all done at once
Old Feb 28, 2005 | 08:24 AM
botemarc's Avatar
thanks
thanks for the reply,
reason I ask this is because I just wanted to see if I can feel the power upgrade or the difference in performace of each mod until the final stage of the Flash.
But i guess it would be cool to just put everything in at once, send the ECU out, and get it back in a couple of days. This way, I can really feel the big/huge gains of the mods....
Thanks again....any more advice?
Old Feb 28, 2005 | 08:25 AM
scott88vr6's Avatar
You would be able to install everything sure, but since you have everything sitting there, you might as well do everything at once.
I did everything one at a time and then the flash at the end but I didn't have the money to do everything ast once either.
Old Feb 28, 2005 | 08:34 AM
botemarc's Avatar
well..
well...i dont have everything yet...i'm still waiting for the TBE, MR BOV, and K&N filter....i also will be installing boost, egt, oil press. gauges...i really have to plan this out, because i dont want to have my car sitting in a spot too long....i need it for work...
Al, would it be possible if I send you my ECU on a Friday and get it back on a Monday? This gives me the weekend to put in everything and start the car again on Monday?....what do you think?
Thanks!
Old Feb 28, 2005 | 08:37 AM
scott88vr6's Avatar
you would have to pay for Al to get it on Saturday delivery which is $$$ much more than just a regular day.
Old Feb 28, 2005 | 08:51 AM
botemarc's Avatar
even...
even if i get it on Tues., i dont mind...as long as I can do my other installation before I get the ECU back...
Maybe if I send my ECU on a Thurs...i dont know...i would have to coordinate something with AL.
Old Feb 28, 2005 | 08:54 AM
botemarc's Avatar
on a side note
on a side note,
the Buschur/Al Alcohol Setup......is this safe for a non-internal mod car, meaning basically what I have setup and then Alcky or would it be too much for a daily driver.....
Is this kinda of setup, a high maintenance setup....because you always have to make sure that your Alcohol level is filled, which basically means double your gas costs?
any response is appreciated...
sleet's Avatar
I would just do everything at once. All of those installs are pretty simple, the longest one will be the exhaust and walbro fuel pump.
Old Feb 28, 2005 | 09:00 AM
botemarc's Avatar
nice...
Buschur 3" Turboback
Hallman MBC @ 21psi
HKS RS Intake
Walbro 255lph Fuel Pump
TurboTrix Tune - 315WHPHey "Sleet"...nice simple setup man....is that a Turbotrix flash or dyno tuned....and you think i would be able to pull out the same numbers with my setup and a dynoflash....thanks
