DynoFlash [Visit Site]
Alcohol kit flash dyno sheet
Old Apr 21, 2005 | 07:54 PM
DynoFlash's Avatar
Originally Posted by EVIL MR
at what boost
23 - 24 peak falling to 20.5 at red line
Old Apr 21, 2005 | 08:00 PM
DynoFlash's Avatar
Originally Posted by EVO8LTW
To get a 30 whp gain with alcohol, do you have to go with a tune that would might hurt the motor if the alky ran out? It looks like the AFRs here are in a range where this car would be well into the 12s without the alky, not to mention the added ignition timing that I'm sure you dialed in. Just wondering if the stock ECU could pull enough timing to save the day.
Do you make the alky tunes more or less aggressive depending on the customer's needs? If a customer wanted to make extra sure that the tune would be safe without the alky, how much could be gained? 15 whp? 20 whp? It'd still be worth the $500 cost even for only a 20 whp gain.
Good question
It is NOT agood idea to test this occurence - kind of like testing a bullet proof vest by shooting yourself
The timing is the SAME as regular pump gas timing - we did not find any significant gains my increasing timing
All of the gains come from the intercooling effect of the alcohol and the increased boost
IF the alcohl runs out or fails under full bost the car will fun mid to high 12 / 1 a/f and prob knock and pull timing. Keep in mind that many tuners tune for mid 12 a/f ratuio - (hard to believe - I know).
In most cases you will prob get away for a short period of time with the failing of the alcohol if you catch it in a reasonable time frame
However, if you keep going on full boost with the failed alcohol kit it is very possible that you may damage a piston
Alcohol injection is not for everyone - BUT - it is a nice mod if you are willing to keep and eye on it and make sure its working
Old Apr 21, 2005 | 08:02 PM
DynoFlash's Avatar
Originally Posted by rlazer5000
^^ I dont know if its worth $500, but Logic Performance makes an alky kit for $250. Im not sure what the difference are, but if ur looking for a cheaper set up, then its a good alternative. Sorry Al to hijack ur thread, im just trying to help out a fellow EVO owner!
No problem
Just rememer you get what you pay for
My kit has been very well developed and specifically designed for evos and works very well and the whole thing is pre-assembled in a brand new sprayer bottle
IDF you buy a do-it-youself kit - make sure you know what you are doing.
My kit is a bolt in affair
Old Apr 21, 2005 | 08:20 PM
EVO8LTW's Avatar
Originally Posted by DynoFlash
Good question
I've got a wideband gauge that has an alarm feature when AFR crosses a certain value and the voltages on a couple of other inputs are also crossed (TPS value, MAP value, etc.). Once I get that set up sufficiently dialed in, I'm thinking about the alky set-up. I'm the nervous type on this kind of thing, but I think with this warning light setup I may be okay. Thanks for the detailed answer.
Old May 2, 2005 | 09:19 PM
sloty27's Avatar
al wut if u have utec..and u have a map that was the alky on it..then have another map witout alkly jus incase you run out??
Old May 2, 2005 | 10:09 PM
Rollaway's Avatar
nice
Old May 4, 2005 | 08:15 PM
sloty27's Avatar
Old May 4, 2005 | 09:11 PM
fromWRXtoEVO's Avatar
No problem
Does it work on the 05 Evo's?
Old May 4, 2005 | 09:43 PM
DynoFlash's Avatar
We have one for the 05 evo - its trunk mounted
Old May 4, 2005 | 10:03 PM
EVO8LTW's Avatar
Will that trunk-mounted kit work in a pre-05 evo as well? What does it use as a resevoir? Price?
