DynoFlash [Visit Site]
gas millage: conflicting reports?
Old Apr 26, 2005 | 11:13 PM
TexasRS's Avatar
On the question of whether a mail-in flash yields better gas millage, a forum search yields inconsistent reports. Some further reports would be helpful, and perhaps Al, if you could chime in as well?
Also, a post from Al seems to suggest (to me) that perhaps gas millege is worse (post-flash) during non-conservative driving and better (post-flash) during conservative driving (e.g., on the highway).
Thanks.
Ps. Just to save "flamers" the time, I know gas millage is far too **** of a consideration for most evo owners, and perhaps it should be...
Old Apr 27, 2005 | 01:23 PM
jimmyv65's Avatar
Flashes only effect open loop operation maps--i.e. foot is being heavy. Most(95%) of your street driving is based on the closed loop maps. Given that(assuming your driving style remains the same) there would be no measuable change in MPG. Period! People how claim a difference have most likely changed thier driving style after getting the flash.
Even the non-flash tuning methods that can effect closed loop operation can't effect it to a noticable MPG change.
I have a dynoflash and it did not change my mileage.
Old Apr 27, 2005 | 03:32 PM
mndeerslayer's Avatar
I increased my mileage by about 4 mpg by adding the Buschur stage 2. Probably from the better air flow through the open filter and 3in exhaust.
Old Apr 27, 2005 | 05:05 PM
DynoFlash's Avatar
Closed loop(02 sesnor feed back) is crusing and idle operation modes the evo sets a constant 14.6 / 1 a/f ratio (by reading back voltage from the 02 sesnor and ajusting the fuel trims - short term and long term) in these phases of operation which entail more highway crusing
Open loop or high load operation is NO feed back and runs off the target a/f maps in the ecu reardless of the actual a/f
Factory goes super rich up top - into the 9 / 1 range
My tune significantly leans out this area of operation to a steady target of approx 11.1 / 1 a/f which would theoetically result in less fuel consumption
Big overlooked factor is that with the reflashed ecu you are making more power so you need more fuel - even though it is at overall effective leaner a/f target
Baically - best way to conserve gas with an evo is to operate as much as you can OFF boost on closed loop
Old Apr 27, 2005 | 06:39 PM
TexasRS's Avatar
Al,
I think I understand, or do I? During your tune you focus primarily on the open loop? And, post-tune fuel consumption during open-loop-use remains about the same (since any gas saved by your leaning out of the a/f is consumed by the greater power output of the engine; i.e., "a wash"?)??? Is that right?
Also, would it be difficult and safe to re-program the "closed loop" program so as to yeild better gas milliage during "grandma driving"? And, if so, would this be something you could do during a custom tune? (And, if you can do it, are there any down sides to altering the fuel economy per the closed loop?) Thanks...
Old Apr 27, 2005 | 06:46 PM
housedj's Avatar
i actually gained approx 6mpg (slow driving) not just from the dynoflash but bcuz i only use 101 octane which burns alot slower & cleaner. my avg is at around 9mpg with normal driving...
Old Apr 27, 2005 | 07:25 PM
UT_Evo's Avatar
house, you're getting only 9mpg? Holy crap... um, just fyi, I drove on open loop just as much before as I do now, and I have about 1-3 more mpg non-highway... Highway has stayed just about the same.
Old Apr 27, 2005 | 08:32 PM
DynoFlash's Avatar
Originally Posted by TexasRS
Al,
Leaning out closed loop would have detremental effects on engine durability - (extra heat) - and would not yield significant gains
You have the open loop figured out
Old Apr 27, 2005 | 08:48 PM
WildRice's Avatar
If I drive very carefully I can get my milage up over 22MPG on 91 Chevron. If I reset my ecu my MPG take a dump downward to about 18. If I am not smoking something I believe this change is due to the ECUs learning capacity. These figures are closed loop driving as it is no trick to eat fuel with WOT or high speed drivng. I have never logged fuel consumption with "76" 100 octane since I only feed her that when I am going to "tear it up."
