DynoFlash [Visit Site]
300+whp, 91 octane
Old May 11, 2005 | 09:25 PM
JSYEVO's Avatar
300+whp, 91 octane
wha twould i need to get 300+whp wiht the 91 octane tune...im getting the hks rs intake, hks dp, hks-hi power...what else?
Old May 11, 2005 | 09:28 PM
Turbo13's Avatar
Post
Basically what I have I would guess. You could do it without cams, but they are so much fun!!
Old May 11, 2005 | 09:41 PM
evo81's Avatar
you can get 300whp+ on 91oct if you get rid of that HKS crap
Old May 12, 2005 | 06:18 PM
JSYEVO's Avatar
what would i need? id like to have that hks hi power though
Old May 12, 2005 | 06:20 PM
JSYEVO's Avatar
how much powe are you making without the cams? and do i need the MBC becuase wont the flash hold it at 19 anyways?
Old May 12, 2005 | 06:24 PM
Evo Ate's Avatar
Arp head studs are always a good idea, along with Walbro 255, and a form of boost control set @ 20-21 psi. That should get you pretty close. With a dyno flash from Al.
Old May 12, 2005 | 06:36 PM
JSYEVO's Avatar
can Al tune it to 20 psi or is the mbc required? what kind of inkake and dp should i use? i dont want to have to modify anything for them to fit without problems
Old May 12, 2005 | 06:37 PM
Evoisdream's Avatar
my profile
Old May 12, 2005 | 09:51 PM
snoop's Avatar
I have VISHNU stage 1 and I got 298WHP avg on three runs. I think you should get close to 300WHP with custom tune You will need a fuel pump and run catless. There are several EVO's in Socal that are close to 300WHP. What is more important is the curve than the max power.
298WHP/298TQ for three runs with custom tune
Old May 22, 2005 | 05:10 PM
mlevo's Avatar
what psi were you runing to hit 290whp?
Old May 22, 2005 | 05:13 PM
snoop's Avatar
23 tapering to 18 at redline
Old May 22, 2005 | 10:48 PM
mlevo's Avatar
Thumbs up
impressive number! woud you go for the stage2 in future ? if you will, what kind of cam combo do you prefer ?
Old May 22, 2005 | 10:53 PM
taenaive's Avatar
23psi with 91 octane? wow, I thought it was too dangerous to go over 21 psi with 91 octane
Old May 22, 2005 | 11:31 PM
snoop's Avatar
23PSI is at 3500RPM's once it is over 4K the RPM goes down to 21. 23PSI at redline would be bad but at redline it is around 18PSI . With MBC and Dynoflash most people I know are running 19-20PSI with out taper while my tune was designed to taper.
Old May 22, 2005 | 11:33 PM
snoop's Avatar
I am done with engine mods since 300WHP was my goal. I made an additional 23WHP on 100octane gas. I think I have strong car since I made around 15WHP less than some cars with same mods plus cams&hotside
